Results 1 to 5 of 5
Thread: Vr starting issue
    VR series 1 Acclaim
    May 2006
    Default Vr starting issue
    My v6 vr has a strange starting issue.when the engine is cold and i turn the key it just turns over without firing.if i then turn the key back to start and try again it starts straight away. This happens every time, in other words it will only start on the second attempt.
    When the engine has warmed up there is no problem. Any advice would be appreciated.
    Thanks, grazman.
    VR_Acclaim is offline Banned
    Vr acclaim
    Jun 2010
    Mine to do this but mines the theft deterNt single I think, um see what error codes u get
    VS Berlina soon to be 5L
    Aug 2010
    Girrawheen
    mine did that for a week it was the fuel pump on the way out then one night parked it up and wouldnt start the next morning replaced fuel pump all good, i have a vs so the same
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Check if it is the fuel pump by listening for it when first turning the ignition on - it should run for about 2 seconds to prime the fuel system.
    VR series 1 Acclaim
    May 2006
    Thanks everyone, i am fairly sure that it is the fuel pump, as i cannot hear it switching on.i think i'll change it before i get stuck.
  1. Starting issue
    By vs2nvi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-11-2010, 01:14 AM
  2. Starting Issue
    By ecotec in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2010, 03:52 PM
  3. VT starting Issue
    By Jjfur87 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-07-2010, 08:35 PM
  4. VP starting Issue
    By Paulib in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-06-2010, 11:11 AM
  5. Vr V6 Starting Issue
    By Chris E in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-05-2009, 10:01 PM
