Hey folks.. So my car got in a prang and ended up being slammed against a kerb. Two wheels demolished. One bent rod at the front which was fixed and the car runs a bit better, but tyres still screech.
I've had a look under the car and there seems to be a gap where exhaust is escaping around the cat.
Will a wheel alignment fix my problem of tyres screeching or should I just scrap the car all together?
may have done some damage to the underside? take it to a panel shop and get em to raid it up and have a look see for you....not a good xmas prezzy mate...what a shame.....best of luck...i hope its all minor.cheers
We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
Unless the car is extra special I'd bin it. Reason is that a hit that was hard enough to demolish 2 wheels will be enough to write off all suspension components on that side front and rear....also probably the subframe will be distorted on that side.
As Commodores are very cheap to replace you could save a lot of hassles. Good Luck in the future.
Explain everything you said above to a Panel Beater or Mechanic and take it from there.
strip the old girl and get a new body![]()
Growing old is inevitable, Growing up is optional.
View my - 97 VS Berlina series2 http://forums.justcommodores.com.au/...ml#post1738670
- 70 HG Brougham Project http://forums.justcommodores.com.au/...-brougham.html
If it is adequately insured, as above, take it to a panel beater.
Yep if shes got good bits,and the body is bent/stuffed,and you have the space do so ? Donate the body to sims metal,get a new body,and start transplanting lol.lots of work but you surely wont be the 1st to have done it.....plenty info on a j/c if you get stuck on the transplants,,,,, best of luck either way,,,have a good 2011
