Results 1 to 4 of 4
Thread: temp gauge
    1994 vr commodore 5ltr V8
    Jul 2010
    blue mountains
    Default temp gauge
    just wanting to know if this is a common problem
    with the temp gauge in a vr commodore
    the problem is that the temp needle doesnt move it stays on cold the whole time i have my car running
    it will some times move just a slight bit and some days it will move a few lines up but not often 99 percent of the time it stays on cold and so i am wondering how to fix this cause i makes me think how hot is my engine really ...
    cheers
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    No not normal at all. You may find it's 1 of 2 things. the connector on the sender unit is not making contact or the voltage regulator in the cluster has a cracked solder joint in it (but the fuel gauge would normally give trouble to if it is the regulator).
    So start with the sendre unit connector.
    and 3 Dangerous non ABS VN's
    Jul 2010
    blue mountains
    ok and where would i find this sorry not that smart when i comes to nachanic work i only know the very basic things lol
    88GreenVN's Avatar
    Jun 2006
    Here is a link I found on the same issue. (2006)
    Temperature sender
    Let us know if it was loose (the connector)
  1. oil temp/water temp gauge wiring
    By HUMBLZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-05-2011, 04:53 PM
  2. temp gauge an fuel gauge not working
    By nathan_867 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-03-2010, 10:55 PM
  3. normal running temp for a VT 5L? and temp gauge..
    By mike49 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2009, 12:57 AM
  4. Temp Gauge went up ??
    By HoldenMan7 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 15-02-2008, 01:14 AM
  5. Temp gauge or fan?
    By The1985divo in forum General
    Last Post: 08-08-2005, 10:18 AM
