Results 1 to 19 of 19
Thread: vn s2 into a vr does the vn s2 have the magnet on the cam sprocket?
    vr wagon
    Aug 2010
    vic
    Default vn s2 into a vr does the vn s2 have the magnet on the cam sprocket?
    hi there, im changing motors in my vr s2, i baught a vn s2 with low kms thinking it would fit but have discovered the vn motor doesnt have a cam sensor, it has a spot ready for it but no sensor, does thr vn s2 come with the magnet on the sprocket ready for the future line say vr s2? im going to change the timing covers but theres no point if i need to change sprockets and timing chains as my vr motor is stuffed due to rooted cam. cheers any input would be apreciated
    vr wagon
    Aug 2010
    vic
    vs commodore
    Oct 2009
    Tamworth NSW
    Just looking through the VP V6 gregorys manual,and the pics show no cam angle sensor fitted ,and theres no mention of it either in the text,so Id say the VN S2 didnt get the cam angle sensor either.Also it shows a pic of the camshaft sprocket,and it shows theres the hole in it for the pickup magnet to go into.
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    Can't you just stick the magnet onto the VN motor?
    Only the VR onwards will have the magnet because VN/VP injectors fired all at once. VR onwards the injectors fire at different times, which is what the magnet controls.
    jetboy's Avatar
    jetboy is offline You learn til u die
    VT exec
    Feb 2010
    Gold Coast QLD
    when u change the timing cover change over the cam sprockets as well an ull be sweet . Cheers
    At 43 a wealth of info , but still heaps to learn
    vs commodore
    Oct 2009
    Tamworth NSW
    Im pretty sure the ecotec (VS) had the first sequential injection system used on the V6..
    vr wagon
    Aug 2010
    vic
    im buying a timing cover so i dont have to pull 2 motors apart, my cam gear in my vr engine is rooted, dont want to spend hours pulling it apart to find teeth on the sprocket stuffed thus why i was aking if they had it ready for future as the timing cover on the vn has a spot for the cam sensor just not machined out.. vn s2 throught to vr s1 are all the same motor.. vr s2 had the cam sensor added. can you buy the magnets? and how would i affix it to the sprocket? cheers
    vs commodore
    Oct 2009
    Tamworth NSW
    The magnet comes in a little plastic cage thing which sort of clips into the camshaft sprocket hole.Ive seen them actually come out of the sprocket,it happened on my VS.$80 for the new magnet from holden plus all the trouble of removing the timing cover etc to find the old magnet and to fit the new one..Ive since seen that in the USA some people glue them into the sprocket hole as they can work loose and came out of the sprocket like mine did.I would have glued my new one in as well if Id known about this at the time.
    vr wagon
    Aug 2010
    vic
    thanks mate makes my day alot better.. how long did it take you to get the timing cover off?
    vs commodore
    Oct 2009
    Tamworth NSW
    Around an hour maybe,but I took my time with it and followed the gregorys manual just to make sure I didnt miss or forget anything.
    vr wagon
    Aug 2010
    vic
    the motor is still out so hopefully less, il ring holden tomorrow and see what i can stick it with aswell thanks mate...
    jetboy's Avatar
    VT exec
    Feb 2010
    Gold Coast QLD
    Quote Originally Posted by CHA53R View Post
    Hope your buyin a 2nd hamdy cause the price offa newbie will floor ya
    Quote Originally Posted by Brett_jjj View Post
    Great info
    vr wagon
    Aug 2010
    vic
    yeah getting a second hand one from the wreckers been priced $100 for timing cover off a backyard wrecker but reckon i can get cheaper
    vr wagon
    Aug 2010
    vic
    got timing cover, camshaft sprocket and chain for $90 pretty good i think
  15. #15
    jetboy's Avatar
    VT exec
    Feb 2010
    Gold Coast QLD
  16. #16
    jetboy's Avatar
    VT exec
    Feb 2010
    Gold Coast QLD
    oh an change ur wiring looms over once u get the old donk out too as there a bastard to do in the car
  17. #17
    vr wagon
    Aug 2010
    vic
    engines out of car doing this so it will go in no probs... no need for new loom... soon my vn series 2 motor will be a vr series 2
  18. #18
    jetboy's Avatar
    VT exec
    Feb 2010
    Gold Coast QLD
    The VN s2 loom wont have the wiring for the cam sensor !!!!!!
  19. #19
    vr wagon
    Aug 2010
    vic
    its going into my vr, vr loom is all still there ready to plug in.. thus why im changing timing covers and cam gear ant timing chain...
  1. Moisture on sub magnet.
    By axemurderer101 in forum Car Audio
    Last Post: 26-07-2010, 06:04 PM
  2. [QLD] WTB- VN6 S1 Timing sprocket
    By wez in forum Swap / Wanted to Buy / Trade
    Last Post: 13-06-2009, 04:20 PM
  3. magnet causing problems?
    By miltiadis_s in forum General
    Last Post: 01-12-2008, 09:23 PM
  4. Transmission Pan Magnet
    By Shounak in forum General
    Last Post: 04-03-2006, 10:50 AM
