Results 1 to 9 of 9
Thread: Something wrong with my transmission maybe??
    VR commodore acclaim V6
    Oct 2010
    campbelltown
    Thumbs up Something wrong with my transmission maybe??
    How it going, allright straight into it, when im driving my gears dont change till it least over reaves uno its not a clean change especialy when i put my foot down and reaches 80 it will keep it there then all of a sudden it changes and im flying whats the deal it feels lyk its slipn gears what do you rekon, also in morning il reverse out fine but then il put it drive and my car will drive soooo slow untill couple seconds is that cause its cold?? thanks people please help
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Have you checked the fluid level? If it is low that could be your problem. If the level is fine you should take it to a transmission specialist because I doubt that you will be able to fix it yourself. Len Voss in Hollylea Rd Leumeah does a good job.
    MY RIDE
    Oct 2010
    campbelltown
    Thannks heapss man i checkd nd my fluid was lyk on kold i think i shuld just get a service, uno how much it is ?
    vs commodore
    Oct 2009
    Tamworth NSW
    Just service it yourself,about $25 for a new transmission filter ,seal and pan gasket which comes together in a kit,and another $20 or so for the 5 litres of dexron111 type trans fluid.Just drop the transmission pan at one end to drain some fluid out of it,then carefully remove the pan with the rest of the fluid in it,then pull out the old filter and seal,push in the new filter and filter seal, and clean the magnet in the bottom of the pan,then put the new pan gasket on with the pan,too easy.
    nathanVY's Avatar
    nathanVY is online now need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    servicing the trans yourself isn't as easy as it sounds, fine if you're mechanically minded and regularly use tools etc, but even if you understand it all but you're not on the tools much you'll find this just a bit of a struggle and will most likely end up with trans fluid on your face/head/hair/neck, etc - trans fluid is THE WORST haha.
    but as brett said, way cheaper. You'd probably have no change back from $150 at a shop.
    Oct 2010
    campbelltown
    Thanks heaps for all your help, no automatic trans mechanics are open so i added sum transmission fluid and it seemed to do the trick nice and smooth gear shifting i will still get a service buh for now it feels realy good
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    You can just drain the oil out by disconnecting the line that pumps into the radiator trans cooler, then connect back up n refill.
    Not the best way to do it, coz u havnt changed the filter, but it gets the oil out without dropping the pan.
    ________________________________________
    VS Berlina soon to be 5L
    Aug 2010
    Girrawheen
    Quote Originally Posted by nathanVS View Post
    Diff Oils the worst, yeah 170 we charge over here in West Australia hate to do the job if your not good with the tools lol
    vs commodore
    Oct 2009
    Tamworth NSW
    I dont get why people think its so difficult to remove the transmission pan and change the trans filter and fluid themselves.Lots of people on here seem to think so,but Its no harder than changing the engine oil and filter.It just takes a bit longer and its a little bit harder to access.Servicing it makes the car run noticeably better too,especially if it hasnt been done in ages.I do my fluid and filter every 3 months,I drive it like a manual a lot of the time,so I like to look after it..
  1. Another Wrong colour fluid in wrong chamber?
    By just_vt_problems in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-08-2010, 07:14 PM
  2. wrong transmission mount?
    By tenggo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-06-2009, 07:36 PM
  3. Replies: 0
    Last Post: 17-11-2008, 01:51 PM
  4. VR TRANSMISSION wrong one??
    By Randy1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-10-2008, 01:32 PM
  5. Code 68 - Transmission Component Slipping - Auto Transmission Only
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 05:14 PM
