hey guys my right hand fog light has stopped working, i suspect a blown globe. Question is how do i change it?
do i have to take the whole fog lamp out?
seing as im going to change one i will do them both, should i stick with the stock bulbs or go something better? any ideas on globe recomondations would be great!!!
cheers
if you stick your head under the bumper and look up,you'll see 2 bolts holding the fog light bracket to the reo from memory,disconnect the wiring,ndo the bolts and it should come out. then theres a screw in a black plastic thing on each side of the the front of the fog light that you undo and the glass will come off.
thats it i think,ive only done it once or twice so im trying to remember...
Easiest way is to remove the foglight from the bumper then disassemble the foglight (by removing the screw holding the silver ring) to get to the globe.
We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
got them out last night, just as i thoyght broken globe. Off today to get some new ones...thanks guys
