Results 1 to 15 of 15
Thread: Gearbox noise in vs v8 series 111
    VS 5L MAN UTE
    Dec 2010
    barooga
    Default Gearbox noise in vs v8 series 111
    Hi all, i got a nasty noise in my gearbox that i just recently found out. The noise appears when the ute is in idle and nutural. Noise disapeares when clutch is pressed in OR when revs are increased. Any ideas what it may be? costs?
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    mine has a T5 and intermittently makes a similar noise, im damn near certain its just a noisy throw out bearing. gearbox needs to come out to replace it, one of those $50 parts that costs $500 to fit im afraid.
    its not hurting anything so i just put up with it in mine
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    If you do not have the required amount of clearance between the throw out bearing and the pressure plate fingers, the throwout bearing will be turning all the time, and will soon wear out. can you see or get yours hands on the throw out fork? you should be able to move/wobble it a bit when the clutch pedal is fully released.
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    VS SS Series III Ute + VZ SS Thunder
    Jan 2009
    Im guessing you have the getrag gear box in your series3, I had the same issue with my gearbox which turned into a nightmare of an issue resulting in 3 rebuilds of the box before the idiots finally got it right, If your in VIC don't go to Trans Diff or Northern diffs same company as they dicked me around hardcore and it cost me a lot of money with my box however back your issue, Can you hear the noise when you accelerate at all or if your hi in the rev range and back of a bit? And is there any whinning noises coming from the box when it in gear at low rev range?
    If so you might have worn the end cap bearings on the input shaft, this happened to me only 300km after the first rebuild as they didn't replace them.
    What state are you in mate?
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    can be caused by an overmachined flywheel creating too much clearance ( as stated above) resulting in constantly replacing the throw out bearing
    (the bearing that pushes the clutch forks in to depress the clutch)
    VS 5L MAN UTE
    Dec 2010
    barooga
    Yeah its a Getrag, iv just pulled the box out praying that thrust bearing was stuffed but it didnt seem to bad???? There doesnt seem to be too much play in the shaft. Is there a way i could test the input shaft? i can spin the shaft without movement or noise or roughness.I could only hear the noise in idle whilst in nutural, i think iv done about 100klm since noticing it
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    i fear we may have overlooked the basics or looked at incorrect bearing
    read this site has good info on diagnosis..
    HowStuffWorks "Common Problems and Other Types of Clutches"
    read all of it before moving forward but due to noise goes away when clutch depressed or revs increased
    i would either go with springs on clutch plate loose OR throw out bearing
    remember the throwout bearing is under more stress when engine running then when is spun in your hand
    another VERY COMMON getrag problem is that the throwout bearing doesnt sit evenly on the shaft properly
    or that its noisy spinning on the inner race INSTEAD of spinning on the bearings in the middle
    the cheapo fix for this is to grases LIGHTLY the input shaft where the bearing fits onto it
    but either way i would be replacing the bearing AT LEAST if not the clutch plate itself aswell (buy a kit)
    and also LIGHTLY greasing the input shaft where the throwout bearing sits on installation..
    hope this helps man!~
    Jan 2009
    The getrag is a good box its just hard to get parts for and that makes it expensive, mine made heaps of noise simmilar to yours and the only way to see what was wrong was to split the box.
    However even now after everything was replaced its still a bit noisy but nothing is wrong with the box. If I had my time over Id just throw a T56 in change the diff gears and be done with it, would of been a lot cheaper then rebuilding the getrag but it does the job, let us know what was wrong in the end though, might help the next person looking for answers on this issue
    VS 5L MAN UTE
    Dec 2010
    barooga
    I have cracked the shits pretty bad with it now!! Many have tried to split the box but got nowhere, rang many "change over" places and the best price was $2500 + the damage of the old box????? I have decided to put it back in with a new clutch kit and prey it can last me a while longer
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    and grease that bugger of a bearing i hope... had another one today but this one spun on input shaft so much it wore a line in it $$$$$ poor bugger
    if you reinstall it you can follow that link to help YOU diagnose where the fault is...
    VS 5L MAN UTE
    Dec 2010
    barooga
    yeah thanks for that mate, its very helpful. I will post when i get the bugger going again
    bpefi is offline Tech
    Hilux Ute - Vs Ecotech Engine
    Nov 2009
    Bundaberg
    Basically on what your saying I would say front input shaft bearing of the gearbox. If it goes away when the clutch is depressed that rules out throwout bearing - as it would be noisy when in contact with the clutch - I do not know much about these boxes - but diagnosis is the same pretty much for all gearboxes.
    VS 5L MAN UTE
    Dec 2010
    barooga
    Gues what????? new clutch kits installed and got an A.O.K in the input shaft bearings and threw it back in and the clunking noise is still there!!!! I think when the gears are bouncing down the road i will get a change over. lol
    VR V8 Manual Wagon
    Jul 2010
    I am not sure how the Getrag box is for gear chatter, The T56 or almost any of the late model Tremec gearboxs suffer from chatter at idle, but it is a problem that alot of gearboxs suffer from and is not nessicarily a big drama. If it were a bearing problem it would be present all the time through the rev range. Alot of late model gearboxs run a spring loaded sling on the drop gear of the lay shaft, sometimes this can fail and the result is gear chatter at idle, which is annoying, but not lethal.
  15. #15
    VS 5L MAN UTE
    Dec 2010
    barooga
    hello guys, i thort i should let you know i found the reason for the noise. It turns out that most of the injectors were almost blocked and causing the motor to vibrate/rock, this apparently caused "gearbox slap" I installed a new set with a new filter and problem solved. Im happy again and the old gurl has stacks of power now
  1. Vy V6 Gearbox Noise
    By tankey in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-02-2012, 11:41 AM
  2. Gearbox clunk noise
    By sleepa in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-07-2010, 03:20 PM
  3. noise in gearbox or tailshaft?
    By commodore1todd in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-04-2010, 08:21 PM
  4. Gearbox noise
    By GusBus in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-09-2009, 11:31 PM
  5. gearbox noise
    By krisjanik in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-11-2006, 08:05 PM
