Results 1 to 7 of 7
Thread: how can i get rid of the exterior trim that goes around my vs ute?
    vs ute manual 3.8
    Dec 2010
    beaconsfeild
    Default how can i get rid of the exterior trim that goes around my vs ute?
    i have seen many vs utes without the trims how do i get rid of mine?
    vs S3 ute
    Nov 2009
    toowoomba QLD
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    which trims? around the tray, around the cabin, the door strips?
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    Quote Originally Posted by redvsutelegend View Post
    Just thought i'd share some info with anyone who wants it.
    I have removed the strips off my old VSII Ute.
    The way I did it was;
    *Sprayed De-greaser all round the car on the top of the strips to let it soak in and soften up the Sikaflex. (Be careful of it running as it does leave a faint trail, this can be buffed off though)
    *After I let that sit for 10 min or so, I got some fishing wire with two bits of wood as handles for ease of work (I used a drum stick)
    *I then ran the line behind the strips, moving up and down slicing the strips and most of the sikaflex from the car.
    *Once all these were removed, I sprayed more de-greaser and let that sit for a few min then rubbed any loose dirty, grimey s**t off with a rag.
    *I then painted on some Turps with a paint brush, letting it soak into the Sikaflex crap.
    *Now, All you need is a simple hair dryer or a heat gun,
    You just hold it over the spot you want to get off for about 30secs or less and then it will just roll off the bodywork by pushing it and rolling it back onto itself with you thumb. I got annoyed at this after a while and started using a rag to push it back and this was much more effective and removed bigger areas of the crap.
    *Then, I de-greased again, then turps'd it again then rubbed any leftover crap off with a clean rag. ( always make sure you use a different or clean rag wen doing the different steps as to stop and crap rubbing back onto the car)
    *Now that this was done, all I was left with were some small brown stains which I haven't figured out how to get rid of, but they're hardly noticeable and the car looks very schmick.
    *The final step was to wash the car, polish the areas with some polish (I use Kitten No. 1 Cream Polish)
    *Then wax the and seal the car (I use Porzelack, which is some good s**t!)
    This took me approx half the day, but best to leave a full day and take it nice and slow.
    Anyways,
    I hope this helps whoever is after the advice to do this with minimal damage or effort
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    5.0L VS EXECUTIVE
    Mar 2010
    There is something called a caramel wheel, the panel shops use, much quicker and easier.
    Do a search and you'll find out more about them.
    96 VS ute, L36 Auto.
    Pacies, 2" catback, 18" RJR Shaddows
    No more V8'S, GT35 TO GO ON SOON
    1999 vs ute series 3
    Oct 2009
    mine peeled straight off no hassels at all mate,
    Quote Originally Posted by Jonnii View Post
    yeah well it is a ute its not supposed to be about comfort
    http://forums.justcommodores.com.au/...rst-car-d.html <<< My 5sp vs ute
    Sep 2005
    Quote Originally Posted by antoniomazzurra View Post
    most are a ^^^^####^^^^ to get off
  1. vs exterior B pillar trim
    By vsdore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-05-2010, 09:21 PM
  2. VR exterior trim
    By jono1492 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-12-2009, 04:14 AM
  3. [VIC] WTB: Red VN S Exterior Trim
    By Tibokan in forum Swap / Wanted to Buy / Trade
    Last Post: 07-01-2009, 03:58 PM
  4. Exterior Door Trim??
    By 1991_Vn2nV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-12-2007, 06:36 PM
  5. HELP! Removing VR exterior trim
    By Summer-Sickness in forum General
    Last Post: 19-02-2007, 07:54 PM
