Results 1 to 9 of 9
Thread: L3 Climate backlight lamps, where to buy?
    VL Commodore
    Dec 2008
    Default L3 Climate backlight lamps, where to buy?
    Hi,
    Both my Lamps are blown on my L3 climate control, where can these be bought, are they some sort of standard lamp that has a name/code to it or it propriety to Delco or whoever make the unit?
    Thanks.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    I think the globes are 1 size bigger (T5) than the trip computer globes in the cluster (T4)
    They are called Neo Wedge. I purchased some LED's a while back and had to shape the top so they would fit.
    and 3 Dangerous non ABS VN's
    aceventura's Avatar
    aceventura is offline Doesn't drive like this
    Mazda 6
    Oct 2008
    SEQ
    Do you mean backlight for the screen or the display?
    If you mean the display, it isn't that easy, but look at Resistors and LED's - replacing incandecent bulbs which shows what I did.
    I couldn't find the correct bulb anywhere, and you can't buy them from Holden. This works ok, but as in the email, make sure DSE have the bulb before you go to the store and can't find it.
    But as 88GreenVN said above you can just use the wedge bulbs and remove the plastic wedge bit.
    VL Commodore
    Dec 2008
    I mean the bulb (or lamp) for the L3 Climate control screen, there is 2 of them on the top of the unit. at the top of the screen.
    I looked up T5 but can't find anything that looks remotely like them.
    aceventura's Avatar
    Mazda 6
    Oct 2008
    SEQ
    I did a lot of searching when mine blew for something the same but couldn't find them anywhere. If you manage to find something the same, great! - but I think you will have to find ~0.5W bulb to solder in. To use the T5 bulb you have to unwire them from the wedge part. When you remove the wedge part they are fairly similar to the wheat grain bulbs from DSE
    Correction: It appears that DSE have does away with most of the small electrical components they used to sell.
    NORTI's Avatar
    NORTI is offline come get me
    VR Calais 5L, WM Statesman
    May 2004
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by Z2TT View Post
    Oh - not the button globes (T5) the tube type globes - my bad. I cut them out and trplace wit hthe LED out of the T5 sized ne wedge LED's I purchased of Ebay. If you just want green (diffuser colour) I'd just purchase a second hand control module from ebay ($20 - $30)
    VL Commodore
    Dec 2008
    Dick smith electronics is not like it used to be anymore, they are by far from the "Tech Xperts". They should just all be converted to Retravision stores.
    Hope Jaycar has something.
    You don't need to make them shine green because the original bulbs don't even shine green it's just a green film or something on the screen that makes the light look green.
    I just want the original bulbs so the light distribution is the same, I tried to put LEDS in there but it just looked out of whack.
    88GreenVN's Avatar
    Jun 2006
    I have a few modules to convert to LED's so I may have a few of the bulbs left over. PM me if you have no luck finding new ones.
  1. No Backlight Illumination on Climate Control VS
    By ivaninoz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2007, 09:11 PM
  2. Climate control backlight.
    By satos in forum General
    Last Post: 19-11-2006, 06:07 PM
  3. Climate control backlight.
    By satos in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-11-2006, 06:58 PM
  4. no dash backlight
    By Simon232 in forum Electrical Wiring / Questions
    Last Post: 17-08-2005, 07:28 PM
