Results 1 to 21 of 21
Thread: Vr v6 auto won't start.
    VR Executive v6
    Jul 2010
    qld
    Default Vr v6 auto won't start.
    Hi just wondering if any one can help me please. My vr wont start I turn the key and nothing the lights work intrument panel lights up. The starter motor did make a clicking sound once. otherwise nothing not even the fuel pump. It did come up with error 31 and 12.
    My key is old prob origanal and the button is missing only used the key manually.
    If any one has any ideas I would appreciate any input
    thank you
    p.s Happy New year to every one on just commodores.
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    VR Executive v6
    Jul 2010
    qld
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    code 31 is Theft Deterent signal, which if your keyhead battery is close to flat then wont return a signal to turn the immobilizer off when trying to start, it should still start but with a 1second delay, if the starter motor clicked then keyhead isn't your problem. If the fuel pump didn't prime check the fuse for it in the engine bay.
    VR Executive v6
    Jul 2010
    qld
    ok thanks I will check the fuse. the nobby bit on the key is worn I was wondering if this is the problem.
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    if the keyhead is completely dead then leaving in the ignition at on position for 1hr from memory it should start after that.
    VR Executive v6
    Jul 2010
    qld
    my husband just tried to lock the car and the key wouldnt work the central locking he had to lock each door individually. So would that mean it is the key? Thanks for the input.
    LS1FUN's Avatar
    LS1FUN is offline Confused with life..
    Black Holden VS S-Pack
    Jul 2010
    I had the same problem with my key a couple of weeks ago. Wouldn't work at all, turned out to be the battery. Needed a new one!
    VR Executive v6
    Jul 2010
    qld
    VR Executive v6
    Jul 2010
    qld
    Hi i have replaced the key with a new one but still wont go. put new battery in just get clicking in the fuse box in engine bay. the doors wont lock or unlock checked fuses under dash. there was a blown fuse for fuel pump changed that. Help please.
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    if it's clicking near the fuse box it's prob the starter relay, swap it over with say the horn relay and give it another go.
    VR Executive v6
    Jul 2010
    qld
    tried that no go. the doors wont even lock or unlock with key. think i might have to get a auto elec to look at it. as there seems no power getting from battery to the car.
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    VR Executive v6
    Jul 2010
    qld
    I checked those and they seem to be fine. i thought it might be the immobiser not going off so will leave key on for 45 min in the morning. i was wondering if it could be the relay that is near the battery i think it has wires going from the battery to it. there are so many things it could be. thank you for replying.
  15. #15
    VX SS
    Jun 2005
    Is the battery ok and charged up?
    When you turn the key to on (not start) does the immobiliser light go out?
  16. #16
    turmoil117's Avatar
    turmoil117 is offline Donating Member
    vn berlina, vr statesman
    Jan 2010
    Westminster
    Is it in park? It's probably not the problem but I have done it so many times.
  17. #17
    VR Executive v6
    Jul 2010
    qld
    the battery is a new one out of my sons car. the immoliser light goes out when i turn the key on
  18. #18
    VR Executive v6
    Jul 2010
    qld
    i have tried to start it in park and neutral but nothing. just the lights on the panel
  19. #19
    VX SS
    Jun 2005
    So the battery is fine, and immobiliser is disarming.
    Are all fuses fine? Any clicks heard from the starter motor?
  20. #20
    VS Berlina soon to be 5L
    Aug 2010
    Girrawheen
  21. #21
    VR Executive v6
    Jul 2010
    qld
    Thank you to everyone the car is running ,the earth wire was lose on starter motor and the fuel pump relay fuse was dead. My new key works now. So a big thank you to all and hope you have a great weekend.
  1. VP V6 Auto doesnt want to start....
    By pipzryd in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-10-2010, 03:00 PM
  2. VS V6 auto sedan, cranks but won't start.
    By Mick131 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-06-2010, 04:18 PM
  3. Auto-start
    By Troy711 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-09-2005, 02:57 PM
  4. bugger won't start (VP V6 Auto Series 1)
    By MagwynTheGrimVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2005, 10:32 AM
  5. help auto to manual convsersion no start
    By 235rwkw in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-07-2004, 04:40 PM
