Originally Posted by
camo89
yer auto mate but the commodore is series 1 and the staesman series 2 proab be different does it mean the gearbox if stuffed when it is just shuttering still drives and down shifts when ya put your foot down it stunk really bad after getting it home after it happened
You've probably burnt/distorted the clutches - check your trans oil and it probably will be brown/black and smell burnt. Sometimes an oil and filter change/flush will fix this problem temporarily and will cost about $80 DIY, whereas changinbg the trans is hard work unless you have a hoist. As Brett says, if the pins match, the ser 1 trans should be OK.
