Results 1 to 7 of 7
Thread: Transmission Troubles...
    2011 Ve clubsport
    Oct 2009
    Wagga Wagga
    Default Transmission Troubles...
    Hi guys..
    My 98 vs statesman has recently started this problem...
    Whilst driving at 100kmh it jumps out of overdrive and into 3rd.? It will not go back into 4th or overdrive until i turn the key off and on? What could it be??
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    2011 Ve clubsport
    Oct 2009
    Wagga Wagga
    The trans was just serviced.. Was doing this b4 the service tho.. And every time i check the codes i get 88? But i cant find a code 4 88?
    vs commodore
    Oct 2009
    Tamworth NSW
    Id try doing the error code check again,theres definitely no error code 88,maybe you are counting them wrong.The first lot of flashes represents 10's,the second lot represent units or ones.For example,4 flashes followed by 5 flashes would be error code 45 and so on.Also remember that it will flash up code 12-(one flash,followed by 2 flashes) before any error codes are shown,it will also flash up code 12 again once its finished flashing up the error codes.If no error codes are set,it will continuously repeat flashing up code 12.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    As above posts, plus could the the TPS faulty, or the electrical connection to the transmission damaged/loose. Did you mention this at last service?
    2011 Ve clubsport
    Oct 2009
    Wagga Wagga
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    it's sits in the throttle body, just be carfull not to loose the spacer when pulling it out.
LinkBacks (?)
  1. car troubles please help!!!
    By VPS2 in forum General
    Last Post: 04-03-2009, 09:28 AM
  2. 5ltr vn transmission troubles
    By madcracker in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-02-2009, 07:59 AM
  3. key troubles
    By alan smithy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-08-2008, 12:45 PM
  4. Code 68 - Transmission Component Slipping - Auto Transmission Only
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 05:14 PM
  5. Auto Transmission Troubles
    By Bex in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-09-2006, 01:58 PM
