Results 1 to 12 of 12
Thread: help help help. vr motor change now no auto works
    vr vs vz
    Jan 2011
    perth
    Smile help help help. vr motor change now no auto works
    help with a issue please.a young guy at work has put a newish motor in a vr using old loom. has now lost the auto and wont drive. has reverse lights when in reverse and everything is connected. he did split the converter and has sperated again to make sure its locked in. motor runs fine and removed tranny pipes while running and not pumping fluid. i asume the convertor is the problem but before i pull it out just thought to ask you young guys in the no if there is a error code i should be looking for. thanks for any help you can give a old timmer:l
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    One assumes it is full of oil and not just 'topped up" Was the newish motor an Ecotec?...if it was then there will be other problems as the VR runs the 'buick' engine which has less electronics. But do the codes check first.
    Good Luck.
    vr vs vz
    Jan 2011
    perth
    tes thanks for getting back to me and it is a buick motor vr to vr transplant and all oils are full
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by peterfishboat View Post
    Are you sure the trans has enough fluid? Did the gear box work before the change?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I think it would be the oil pump not pumping for some reason or other....no funny noises when idling like tinny rattling?.....trans wasn't dropped hard on ground when changing engine causing oil filter to dislodge and prevent oil pickup?...bellhousing bolted to engine with no problems like needing to be forced those last few mm?.....done a codes check yet? Are you triply sure the oil level is correct as a lot would have been lost when the converter was disconnected.
    vr vs vz
    Jan 2011
    perth
    thanks guys 4 getting back to me . ok ill start with he drove the car untill transplant. he removed the motor and trans then splitt them but forgot about converter bolts. with my instructions over the phone i went through step by step to install converter and locking it to pump. so after he told me it wouldnt drive i went around to have a look and removed flex cover undid the converter bolts as was able to move converter back in pump with a screwdriver so im assuming its seated properly. then i undid trans lines to radiator to check for fluid ... none.. so im pretty sure he droped converter hard on ground or something along those lines... im sure pump will work even with error codes.BUT i may be wrong. my next question would be would a error code stop the pump. unlikely but ill ask anyway. when its running there are no noises and when reverse is selected we have reverse lights. i went through how to do error codes with him and he said that the thermo fan cut in??????? dont no what the hell that is . iwill go 2morrowand check.
    vs commodore
    Oct 2009
    Tamworth NSW
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    does the fluid level go down with engine running compaired to cold engine off? if it doesn't then the pump isn't working. Id first be dropping the pan and check over everything, the filter could have dropped a bit so it's not sucking oil up anymore.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Sounds like you will have to remove trans and reinsert converter to bellhousing/pump ensuring it is fully seated and does not slip out when bolting up. Keep you fingers crossed that the locating tangs are not damaged. Re codes, not sure if they start recording without VSS registering speed so there may be none (not that it really matters). Brett or The1 should know when codes can be logged. Good Luck.
    1996 VS BT1 SS 5ltr original
    Apr 2008
    With the buick the thermo turns on when you run the error code test, i guess it is a good way to no you have got the right pins. Codes will log as soon as the computer relise's there is something not connected right when the ignition is turned to fire the car up.
    vs executive s1/ vz berlina
    Mar 2008
    The way you describe it, its the tranny pump causing this, probably when he put it back the converter not properly in and tightning the bell housing bolt will straight away snap the pump gear, its either change just the pump or get 2nd hand.
    vr vs vz
    Jan 2011
    perth
    quick update guys he broke two locating lugs for converter. thanks for help and advise .. cheers
  1. VE SV6 200 H0 Motor Auto 2008 Transmission Change of Auto oil
    By markholland in forum VE Holden Commodore (2006 - ?)
    Last Post: 31-01-2011, 05:24 PM
  2. Possible to change auto trans in a VR V6 without taking out motor?
    By mike49 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-03-2010, 01:03 AM
  3. i have a vl 6cyl just had exchange motor put in, the cars factory auto the new motor
    By highmat_8686 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-11-2008, 09:32 AM
  4. VX headunit works and doesen't works
    By kaishiz in forum Car Audio
    Last Post: 13-09-2007, 01:38 PM
  5. will a manual box starter motor fit on a auto box motor?
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-09-2007, 05:17 PM
