Results 1 to 10 of 10
Thread: VS Berlina makes Creaking Noises while driving
    VE Calais
    Dec 2010
    Default VS Berlina makes Creaking Noises while driving
    This is my 1st post ever.
    Ive a VS Berlina and I lowered it with pedders springs some time back and I love how low she looks.
    Anyway the problem is and I assume from it being lowered is ive stressed the steering/suspension/struts a bit.
    The car when i turn and more noticably on the left side makes a creaking noise.
    I took the front passenger wheel off and noticed that there is a metal shaft attached to the strut vertically. The bushes(rubber grommits) or whatever theyre called are totally off the top part of the pin and on the bottom part its absolutely split.
    It looks like I need new bushes (rubbers).
    Where do I get them from and as I dont know what theyre called or what the tyre/strut arms are called im not sure what to ask for.
    I can post a pic up if need be.
    Im also not 100% sure ive creaks coming from other parts of the car. Always happens when im turning, even a small turn.
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    this is called your LINK PIN
    it attaches the SWAY BAR to the STRUt
    the parts you need are LINK PIN BUSHES
    and (four?) new NUTS
    the nuts stretch when fitted and should be replaced with the bushes
    fault is very common and parts are readily available from holden OR you could upgrade (next to no difference in handling though they just last a little longer)
    http://cgi.ebay.com.au/Commodore-Hea...item45f7caaf19
    VE Calais
    Dec 2010
    Thanks heaps for that,
    That looks exactly like what I need
    I hope theyre easy to replace and hopefully that gets rid of the creaking noises.
    Im looking to sell the VS soon to get a VE Calais.
    VE Calais
    Dec 2010
    Hey thanks for your help,
    I ended up buying these Commodore Heavy Duty Sway Bar Link Pin Upgrade Kit (eBay item 320596959290 end time 27-Jan-11 11:01:11 AEDST) : Cars, Bikes, Boats
    I noticed on the VS that the pins are straight where as these are slightly bent but I guess its all the same.
    With the Urethane bushes is there anything I need to know re tightening them up??
    Also are there any things I need to look out for, ie once I take the old pin out is it easy enough to put the new pin in?
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Quote Originally Posted by zac_sa View Post
    Yep that's fine. Different brands are slightly different. Genuine to suit vs is straight whereas many of the aftermarket replacements (particularly the heavy duty) have slightly bent and offset ends. Work just the same.
    The urethane bushes tighten up just the same as the standard rubber bushes, keeping the big/small end of the bush and the metal discs in the same sequence. Tighten until the nut locks up when it runs out of thread on the rod. Since the link rod will try to spin as you tighten the nut, I just put a set of locking pliers onto the rod to stop this. Some link rods will have a 10mm form on them so you can also put a spanner onto them.
    Basically, installation is the reverse of removal. To get the rods out/in, you'll need to have the steering on full lock and flex the front swaybar down with a good prybar. I do this with a prybar under the k frame (engine cross member) and lever down on the swaybar. Don't be afraid to use some force as some of them can be a real pr#ck (particularly the genuine rods without the kinked ends).
    Also, it's hard to say without actually seeing it, but there's also a good chance your noise could be your top strut bearings from your description of when/how it happens. If your new link rods and rubbers don't get rid of your creaking, this is what i'd be looking at next. They're about $15 each from memory.
    Cheers,
    Chris.
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
    VE Calais
    Dec 2010
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    above 100% correct
    the strut top mount bearings OR bearing plate get old and wear out they allow the strut to pivot on the front weight of the car allowing steering
    to remove you need spring compressors and a carton and patience a novice would be best to replace the BUSH (top bush bearing sits in aswell)
    but sounds like its just the link pins~!
    VE Calais
    Dec 2010
    Ok, this afternoon my link pins arrived in the post, so I was keen to tackle this and replace the severly worn pin/bushes.
    It wasnt as straight forward as I thought. I jacked up one side and removed the nuts eventually. I couldnt get my damn socket in due to the lack of clearance to get the socket over the nut.
    So ring spanner and limited to 1/3 turn it was.
    When I got the nuts off I had dramas with the sway bar not being able to slip off. I quickly did a search on the forum and while theres no real answer it seemed to be the easy way to remove the other side. You dont want to know how I got the whole front end of the car up since ive only got 1 Jack.
    Anyway taking off the lower nut on the link pin from the other side helped give the sway bar some slack to get it off the old link pin and slide the new one in.
    Due to the sun going down ive not yet secured the 1st link pin in and will do it tomorrow.
    What I want to know is how tight do I do the nuts? ive the blue urethane bushes. How much should I compress or make them bulge?
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    only need to be tight enough to not come loose
    so lets say like a spark plug?
    oh fyi start all the nuts before you do any of them up (word of advice here)
    VE Calais
    Dec 2010
    I guess I did the nuts up too tight, I noticed the bushes and mainly on the ones that attach to the sway bar were becoming deformed. I loosened them up. Ive not dealt with Urethane bushes before but anyway I think I screwed them up as now they are in a weird shape.
    I can see that they may sheer off now as they wont go back to their desired shape.
    I just hope it lasts a month or so before it needs to get jacked up again.
    Oh the ringing noise is now gone but the creaking is still there. Only seems to be right hand turns. So the strut top bushes/bearings need doing too I suppose.
  1. Did an oil change and engine makes louds noises
    By Delo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-10-2010, 08:36 PM
  2. help!! vt makes nosie when driving :(
    By DvS_Ls1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-05-2010, 10:19 PM
  3. mates VS makes beeping noises while driving? maybe an ecu error? anyone know?
    By <atomicL93> in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-01-2010, 08:54 AM
  4. Steering makes grinding noises
    By HsvMan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-10-2004, 02:59 PM
  5. VT Berlina door noises
    By crocco in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-05-2004, 08:39 PM
Tags for this Thread
