Results 1 to 10 of 10
Thread: mace memcal for vs pros cons
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Default mace memcal for vs pros cons
    hey has anyone got a mace enginering memcal in teh vs commodore v6?
    wanting to get one but just want peoples feedback
    greenfoams tune dnt like me vs lol waiting to see wen delcowizzard can do one but wanting to experiment with different ones
    sooo yeh r they any good?
    cars a VS commodore 1996 series 2 with 141 000 on the clock
    i got:
    -CAI
    -high flow filter
    -pacemaker extractors
    -2 and half inch exhaust
    -plenum spacer
    -corvette servo
    -soon to be stage 2 shift kit
    later down the rack i want to get high ratio rockers
    `thanks
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    What exactly was wrong with foams tune mate?
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    kept pinging, hes tunes are really good but my car is just retarded lol (few mates have his tune and no problems)
    i changed plugs to cooler ones fuel fiter used high octane fuel sent it back a few times, i gave up in the end lol, im in no way saying foamys tunes are crap or bad, thre really good tunes but it jist wasnt right for my vs, could be somthing else wrong with me car dunno.
    vs commodore
    Oct 2009
    Tamworth NSW
    Maybe theres something wrong with the memcal itself,it does happen from time to time,I do my own tunes for my VSV6 ,and Ive got the timing wound up a fair way compared to standard,and it still doesnt detect ping or knock unless its flat to the floor in a higher gear etc,when its freely reving through the gears theres bugger all pinging or knock detected.And when it does detect a certain amount of knock via the knock sensors,the ECU will instantly read from a different timing table called the low octane timing table, which obviously has lower timing values than the high octane or normal timing map.If you can actually hear the engine pinging/knocking,then theres something very wrong.The knock sensors should detect the knock or pinging, and deal with it instantly via the ECU, long before the pinging would usually be heard..Also maybe the knock sensors are not working properly.They screw into the water jackets on each side of the block,so it might need a good flush out too as it can fill up with mud and crap.They definitely would be worth checking if you have this problem happen again once another memcal is fitted.
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Are you sure it's pinging? What sort of fuel are you running?
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Quote Originally Posted by Brett_jjj View Post
    cheers for that, will have to check that, its been over a year since i got the tune from grrenfoam lol but useing stock memcal atm. yeh he said the same about it should detect the ping and adjust biut it never did, it pinged around the 2500-3000rpm mark pretty bad (sounded extreamly bad)
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Quote Originally Posted by wraith View Post
    yep definally pinged, tried runing it down as much on fuel as i could (like 5 litres left) then filled up with 98 from caltex, that didnt work so straight after that tank i filled up with BP ultimate and still teh same
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    do you have a k&n type oiled filter on the intake? give your MAF a good clean. if it is dirty it doesn't read right, a tune with some extra timing in it may very well make it ping.
    a vacuum leak through the climate air system can stuff up the tune as well
    Body by Holden, Soul by Brock
    the Legend will live forever
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    What spacer is it? Depending on what's being changed in the tune it can upset the fuel trims quiet a bit. I have been working on a tune for this myself of late. Could give you one to try if your interested.
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    I have had both greenfoam and mace's memcals and loved them both.
    Maces feels a bit more refined, whereas greenfoams was quicker 0-100.
LinkBacks (?)
  1. pros and cons
    By SAV_117 in forum The Pub
    Last Post: 29-08-2009, 09:12 PM
  2. Super 6 Pros and Cons
    By King_berald in forum V6 Development And Modification
    Last Post: 06-05-2009, 11:19 PM
  3. LPG - Pros V Cons
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-11-2008, 01:56 PM
  4. Pros and Cons of VY's?
    By 1vngal in forum VY Holden Commodore (2002 - 2004)
    Last Post: 31-07-2008, 07:49 PM
  5. Pros And Cons Of A Shift Kit
    By weedo_86 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2006, 11:22 PM
