Hey Guys,
I know and I think this has already been asked and answered before, but not for the life of me could I find any post using the Search function.
Looking at getting a VS with a Stuffed Gearbox at the moment. I have a VT Gearbox with nothing wrong with it out of my Berlina. What would need doing if I was to put it into the VS? Would the VS tail shaft need modifying?
Thanks in Advance
Mumbo
If it's not a Symptom its not relevant, and if its not relevant I don't care!
i would think sraight swap ut dont take if from me i got no idea dont really help you but
Yes you can use a vt auto box in a vs. It will run fine off the vs pcm and you use your existing vs tailshaft. You'll have to grind away a bit of alloy on the vt box bellhousing to clear your exhaust. A vt box is much stronger than a vs.
Z' Series HSV 297KW 6lt LS2 Conversion For Sale!PM Me For Details
Yeah knew the VT box is much stronger hence the fact wanting to put one in LOL. Awesome as, thought you would need to Modify the Tailshaft but if it will go right in, then all the more better![]()
1. VT-On wont fit into Pre VT cars with out modding the exhaust. Which is a pain as there ain't no room to run a good flowing exhaust. However the series 3 VS Ute runs the same box and has a modded bell housing and cover plate which allows you to run the factory VS exhaust.
2. VT-ON runs a New design Torque converter which cant be used with the Pre VT computers as what VT_Acclm has said about the software. There is a new valve design in the valve body but it the same shape and the VT just runs a better sleeve to stop ware in the bore.
3. there is no way the trans would work 100% if fitted in a VR the 3/2 kick down is totally different and the lockup is totally different the life span would be shorter than the correct box.
4. To fit into a VS the VS converter would need to be used and the Series 3 Ute bell housing would need to be fitted but i have never tried it and will never try it.
We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
VT Box Being Stronger than VS? Wouldn't that Depend on which box your VS has to begin with?
VS Had a few different Auto boxes, example the Towing Pack and Supercharged models had stronger boxes.
Hmm, not here to argue, but not all entirely correct imo.
1. If you modify the vt bellhousing you won't have to touch the stock vs exhaust. Yes a series 3 vs bellhousing would be ideal but they're very hard to come by (especially without the rest of the box attached and the OP wants to use a vt box he already has). The vt bellhousing is modified to similar replicate a vs series 3.
2. This is correct and I failed to mention it. You MUST use your existing 1800 stall vs torque converter.
3. The OP wants to fit the vt box to a vs (i.e electronic, not cable kickdown). A vr was never in question (but you're right it can't be fitted to a vr).
4. Refer 1 & 2.
"1. VT-On wont fit into Pre VT cars with out modding the exhaust. Which is a pain as there ain't no room to run a good flowing exhaust. However the series 3 VS Ute runs the same box and has a modded bell housing and cover plate which allows you to run the factory VS exhaust.
4. To fit into a VS the VS converter would need to be used and the Series 3 Ute bell housing would need to be fitted but i have never tried it and will never try it."
NOW THIS IS ONLY TELLING ME INFORMATION IF THE GEARBOX WAS AUTO, WHAT IF I WANT TO PUT A MANUEL VT BOX INTO MY VS SER 3 UTE? IS THAT POSSIBLE
Why must the VS torque converter be used?
This is why
