hey guys i was just wondoring the stock white lights behind dials on dash im going to change what light size will fit in there the t5 ? or t10 i have brought a pack of t5s but if i take a part to see if they fit i wont be able to drive to shop to get more so i need to know what size and how manny i will need tha
(C.C) COMMODORE CREW
Depends on a number of things as 2 how many u need. R u only doin the cheap way and replacing the globe only? if so heres a simple list, but ur main thing u urself need 2 check up on is wat type of heater control PCB board u have? theres 3 types only way 2 tell is if u pull it out and have a look.
Cluster: 5 globes t10
LCD screen: 1 (base models) 3 (higher end models)
All switches: 1 globe each (hazard, fog, trac, power, rear window switch, mode button ect...)
Auto: 1 globe
Power window switch block: 4 LEDs (not globes)
Ignition ring: 1 Globe
Heater controls unit type 1: 6 globes
type 2: 7 globes
type 3: 7 globes
Climate control: 6 globes
Headlight switch: 3 globes (soldered in place)
Bare in mind all these globes vary in size and shape so u may need 3mm LEDs in some places and 5mm LEDs in others
We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
ok cool thanks
I got all globs and have finally done it it looks grate =] also did trans light behind hazards demister and aircon butten globs
thanks for help
Cant wait to get ps so i can drive bye my self with thyem on
