Results 1 to 2 of 2
Thread: Climat control dosent work in VS berlina :(
    VL berlina - Daily / VS Berlina - Project car :)
    Aug 2010
    Craimore, SA
    Default Climat control dosent work in VS berlina :(
    Ok ppl i have had this issue for sum time and now i give up...time to resort to the internet lol
    Ever since i've had the car the L3 Climate Control does not work at all, doesent even want to turn on...i've replaced fuses, looms, relays and still doesent wanna work
    Any help would be much appreciated thanx
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    I would check fuse 17 as its the ignition fuse that runs the climate control panel also fuse 1 witch is the battery fed fuse for it.
    Quote Originally Posted by SikVScommi View Post
    f the tap can be moved by hand, check the postion of the heater tap changes between (manual) hot and cold. If it doesn't, then you can chase why.
    If the other controls work - vent position etc. - there must be vacuum present = one-way valve, tank etc. not leaking.
    The solenoid controlled valves that direct vacuum through the system are behind the oddment tray, under the radio. It's possible that the one that moves the heater tap has died. If you pull the climate control display out and switch the system from full cold to hot, the solenoid should actuate. (Working out which it is if it isn't working will have to be a process of elimination, noting which solenoid works as the climate controls are used.)
    If a test light indicates there is power and an earth across the solenoid wire, it will be the solenoid.
    There's also a temp. sensor on one of the pipes to the heater core (in car, behind the climate control display) that won't allow the heater to work if the heater (engine) is cold. Perhaps that has died or fallen away from the pipe.
    The display units can also stop working properly.
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
  1. Vx ss ls1-abs & traction control lights stay on & traction control switch not work-
    By VTLS1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-01-2011, 05:57 AM
  2. will vs climate control from a berlina/calais work in an exec?
    By nicevs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-08-2010, 09:23 PM
  3. vr berlina wiring diagram needed, climat control problem
    By vrberlina5sdp in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-08-2006, 09:20 PM
  4. climat control in a vs
    By bjk87y in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-08-2005, 01:37 PM
  5. Climat controll
    By hispeedvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-07-2005, 05:44 PM
