Results 1 to 6 of 6
Thread: help { hydratrac diff }
    94 vr HSV gts 6speed 5.7stroker 215kw
    Jun 2009
    no where
    Question help { hydratrac diff }
    hi there everyone,im not[[ boosting]]about this! it is a simple question i need to get some help with. i did a standing start burnout in a straight line the otherday,i turned the car around to go back and have a look a the rubber on the road,it looked like this. in first gear the two wheels spun second gear both where spinning i got into third gear and it went into a single spinner,would anybody know if this is the way the hydrtrac diff works it seems strange to me as it seems the lsd stopped working for some reason
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    Quote Originally Posted by go fast View Post
    From my limited knowledge, a Hydratrak differential is a LSD. However, it's a speed sensitive rather than torque sensitive LSD
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    Sep 2005
    Hydratrak limited-slip differential uses a cartridge-type
    fluid coupling, which progressively and smoothly increases torque transfer to
    the wheel with traction. This is in direct response to the reactive speed
    difference between the wheel with traction and the opposing, faster rotating
    wheel -- the wheel that is slipping. Thus, the more one wheel slips, the more
    useful traction that is transferred to the opposing wheel.
    The standard holden/BW lsd is a plate-type (act just like little sprung clutch plates) that locks up fairly rapidly and sharply if one wheel spins faster than the other. They can be taken out and torqued up tighter if you want less slip before it starts turning the other wheel as well. The downside is that they lock up just as sharply at low speed, which the viscous type don't, so the rear drifts out more easily if you provoke it in a corner at low speed - but fun as long as you're ready for it!
    Jun 2009
    no where
    Jun 2009
    no where
    buy the way thanks for the reply and the infomation about the hydratrac diff
    Sep 2005
    no worries nelson.....i
    have a good 1////best wishes
    yes shes working prop as far as i can work out from what you have said......best wishes
  1. [SA] WTB- 3.89 diff gears to suit borg warner diff
    By GTP 85 in forum Swap / Wanted to Buy / Trade
    Last Post: 31-05-2010, 01:23 AM
  2. 304 I need a new diff.. well I want a new diff..and mine's noisy..so..I need a new diff.
    By Warranty Void in forum V8 Development and Modification
    Last Post: 24-05-2010, 02:19 PM
  3. [VIC] V8 3.45 diff gears out of vs gts hydratrac lsd diff
    By pugga in forum Parts And Other Items For Sale
    Last Post: 17-03-2010, 09:31 AM
  4. hydratrac
    By Mr.Jones in forum General Discussion
    Last Post: 25-09-2005, 12:24 PM
