Results 1 to 6 of 6
Thread: vr not wineding over
    VR S Pak
    Jan 2011
    Hay
    Default vr not wineding over
    Hi, i have a Vr s pak, had it running went for a drive and turned it off. Now it wont wined over, the starter motor ticks. i have a new battery in it, i new starter motor but still does the same thing. With a jump pack attached to the battery the starter motor still ticks but engine wineds over a little bit. engine can be wound over by hand. Please help?
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    alternator may have died....and running jumpers into a dead battery will give you the result you got>? try to recharge the battery (on a charger) take the car for A Spin with the lights on...if the same thing happens on your return it may be the alternator > similer thing happend in my vt......
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    jetboy's Avatar
    jetboy is offline You learn til u die
    VT exec
    Feb 2010
    Gold Coast QLD
    New battery ?? New starter ?? did u replace these because of the problem are they brand new items ??? . Cheack all your leads and connections make sure they are all clean and tight including your earth strap , check your starter relay it maybe shot swap it with say ur high beam one an give that a go
    At 43 a wealth of info , but still heaps to learn
    VR S Pak
    Jan 2011
    Hay
    recently put a new engine in the car, i replaced the battery before getting it going then after driving it it wouldnt wined over and the starter motor ticked when turning the key, sounding like the solinoid was gone so i replaced the starter motor. i have changed the relays and no changed, and i have been right over the car checking for leads off. i might try running the engine with out the belt seeing if the altinator is shot. Whats the earth strap?? and other ideas??
    VS ute
    Jan 2010
    townsville
    check to see if the battery terimanls are loose and tighten if necessary.
    also have a look at VS v6 owners check this out
    Sep 2005
    as stated>>1st recharge battery in charger?stick it in the old girl(your car) if the car fires up? take it for a 40lm spin with the lghts on>>if she come back and dosnt fire up its the alternatore? get rid of the alt with the cheap test and if it isnt the alt you can at least take that of your list? when the car is running ac,stereo,lights and so on it puts the alt underload and it may have just given up the ghost?
    Quote Originally Posted by ellis18 View Post
