Results 1 to 4 of 4
Thread: VS petrol tank in VH for LS1
    VXII SS
    Apr 2005
    VIC
    Default VS petrol tank in VH for LS1
    Hi all,
    We are putting an LS1 into a VH, and are using a VS sedan tank.
    What fuel pump setup would be best to use?
    Can i use a VS sender unit, but with a bigger/more powerful pump instead of the V6 one?
    Should we use an external pump?
    Thanks.
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    ls1 uses 28lb injectors i think vs v6 20lb the intank pump from memory is the same for both v6 and v8
    VH LS1
    Sep 2007
    NSW
    How did you go with the tank? I'm starting the same conversion and wondering the same thing.
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    decent bosch pump smaller than the 044 should fit, maybe a walbro as well from what ive read (walbro is apparently quieter than a big bosch pump too)
    as for an external pump, and ya might as well put in a surge tank as well if you're going that far... for a mild street cruiser, not needed. however if u intend building it into a wild boosted/big power/strip/track toy then yes it would be a wise idea
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
  1. Drop Tank.. Lowering Petrol Tank..
    By anton1o in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-05-2010, 05:52 AM
  2. petrol tank
    By vp_kid in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-06-2008, 08:53 PM
  3. Petrol Tank
    By mr_vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-08-2005, 05:12 PM
  4. Petrol Tank???
    By ElDubya in forum General
    Last Post: 11-07-2005, 10:03 PM
  5. Petrol Tank Size
    By Secki in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-06-2005, 04:08 PM
