Results 1 to 13 of 13
Thread: Having to jiggle tbar to get rev light to work,
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    Default Having to jiggle tbar to get rev light to work,
    hello,ive noticed that when i revurse that i have no rear rev lights>? if i jiggle the tbar it fires the lights up,same as starting> sometimes i put the key in the ign and she wont fire up? again a tiny jiggle of the tbar and she fires up every time its a v8>?my mate said its some linkage under or near the gearbox and it needs ajusting? would he be right?..........thanks heaps on advance for all replys.best wishes and kind regards
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    There's a switch on the shifter that won't let the car start in gear. Can't remember what it's called. It might need adjusting.
    I'd imagine the reverse light issue is pretty simple ie: loose wire or something, or could be related to the above, not reading that it's in reverse.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    Sep 2005
    yes i understand your point 100% but both issues are fixed by a jiggle of the tbar? there may be 1 thing down in the gear box erea that ajusts them both.you may be right...thanks a heap for your reply,,,,,im sure plenty of ppl will let us both know in time,,,thanks again
    Quote Originally Posted by Hangman View Post
    I'd imagine the reverse light issue is pretty simple ie: loose wire or something.
    Hangman's Avatar
    Jan 2010
    Yeah I edited to say the switch might be causing both issues. Someone will know for sure.
    Sep 2005
    thanks champ for the lightning fast reply
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    Sounds like the inhibitor switch, fairly common problem, you will find you have to hold the t bar up towards park and then it should start.
    As for reverse lights, similar to above, might be some loose/half broken connection of some sort activating the lights
    Sep 2005
    somthing that has to be done from underneath? thanks for the fast reply....have a good 1
    Quote Originally Posted by Verynice View Post
    Hangman's Avatar
    Jan 2010
    It's on the shifter under the console.
    vpcalais6's Avatar
    vpcalais6 is offline F#%ING [P] PLATER
    V6 manual vp Calais
    Sep 2007
    central coast
    Quote Originally Posted by justbad4you View Post
    Just take you console off around the tbar you will see the enhibitor switch it's only two screws and afew wires
    CHEV badges Australia says no
    fighting online is like racing on a special olympic. Even if you were to Win! your still ####ing retarded
    Verynice's Avatar
    VS Caprice 5L
    Aug 2008
    Yeah its not hard to get to though, pop up the t bar surround, then 4 screws hold the plastic 'cage' around the tbar. Im not sure which connections are what though, i havn't had to deal with them before.
    The inhibitor switch prevents the car from starting in gear, so if PARK isn't engaged properly, you'll have to kick it up when u start it. Happens with my car too lol.
    Hangman's Avatar
    Jan 2010
    Just had a quick search and found this.
    How To Repair Reverse Light Switch on Auto VR/VS Commodore
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    When you locate the inhibiter switch, first try loosening the 2 screws hold it and move it forward/back with ignition on and T bar in reverse - at a certain spot the reverse lights should work - tighten the screws there. There is very little adjustment, actually I don't think they are designed to be moved - just replaced. On mine I ended up placing a thick washer under one of the mounting points to raise that end and tilt the switch a bit to give me the adjustment I needed. I reckon it's best to try and adjust the old switch before buying a new one (~$50) or trying to fix the old one.
    Sep 2005
    Quote Originally Posted by hako View Post
    thanks hako,ill get a new i and take it from there....thanks a heap for your reply,hope the weather up in QLD has settled down...thanks again
  1. column shift gear box in normal tbar auto
    By james90 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-09-2010, 09:34 PM
  2. vt bar and light on vx commodore? will it work?
    By feet eatin chickens in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-10-2009, 04:06 PM
  3. [VIC] 3x Lithium Ion Cordless LED Work Light
    By Noy in forum Parts And Other Items For Sale
    Last Post: 04-06-2009, 03:10 PM
  4. Colmn to Tbar
    By BUSTER1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-03-2009, 01:00 PM
  5. VT brake light doesn't work when headlights are on
    By dephilile in forum Electrical Wiring / Questions
    Last Post: 08-12-2006, 04:35 PM
