Results 1 to 14 of 14
Thread: anyone want to trade there 2 seats for my 3 seater in vs ute
    VS ute
    Jan 2010
    townsville
    Default anyone want to trade there 2 seats for my 3 seater in vs ute
    hey all,
    Im looking at doing a 2 seat conversion in my vs ute. I have done a bit of a search and most threads on here are about converting from 2 seater to 3 seater.
    So I was wondering if there is anyone who wants to trade there 2 seater setup with centre console, handbrake etc for me 3 seater setup?
    cheers,
    patrick
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    two seaters use a tbar? 3seater use a collem shift....so you would need some 1 doing a two seater to 3 seater convertion with a collem shift(wow i wish you lucck as i dont thing many ppl go from2seat up to 3 seats and as 3seaters utes are way less popular.just go to the wreckers and get two fron seats for round $100 and see if you can recoup somthing on ebay with you 3 seats
    Quote Originally Posted by patskies View Post
    hey all,
    cheers,
    patrick
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    White Tiger's Avatar
    White Tiger is offline Semper Fidelis
    VN Executive Wagon VR Berlina V6
    Jul 2009
    Bordertown SA
    you only have to change the passenger seat or are you after higher class seats?
    and the tbar doesn't go straight in cause there is no mound for it so you will have to either use an after market shifter or make spacers.
    however if its manual it will be easier as they are already floor shift.
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    The column auto gearbox selector shaft sits in a different position to the T/bar aswell.
    VS ute
    Jan 2010
    townsville
    sorry guys forgot to mention that its a 5 speed Manual.
    I would like higher class seats but most importantly id prefer a centre console.
    I gather the standard "bucket" seats just bolt straight in?
    Sep 2005
    then best bet is to get 2seats and a 5sp console with an armrest from the wreckers or ebay(i realt dought youll get a swap)
    VS ute
    Jan 2010
    townsville
    yeah i wasnt expecting anything but no harm in asking.
    will the hand brake for the centre console bolt straight in? and will i need a different hand brake cable for the centre console hand brake
    Sep 2005
    thats true.youll never never know unless you give it go as thay say
    vp senator & VS Ute
    Apr 2005
    I rang Q!ld Transport about the aftermarket seats in my VS ute and was told they needed to be inspected and certified with a mod plate to be legal. I was asked at the time is it a 2 or 3 seat ute.
    shown on the manufacturers plate. I told him it shows 2 seat capacity and was then told if it was a 3 seat then it must be certified and mod plated if it was changed from 3 seat to 2 seat to keep it legal. Might pay to ask Qld Transport. Cheers.
    Sep 2005
    Quote Originally Posted by redvpsenator View Post
    HOWDY RED. MATE im having probs asnwering that private message(somthing aint right with my message thingy) every time i try and send you what wrote i the page resets) when its fixed ill send of the mail....sorry guys to jump on the post
    VX SS
    Jun 2005
    Handbrake will work and there should be the spot for it in the transmission tunnel, just covered up with some sound deadner.
    The only thing is, there will be a hole in the middle (covered up by the console) because the cars which had the handbrake in the middle had a moulded bit underneath for the handbrake rod to pass through to be bolted up to the equaliser.
    Sep 2005
    it will but im not sure if it will leave small gaps for air to come up thru were you putting tthe hand barke...when my mates was doen it has spaces for air to come up(not norm) so he put some expanda fome in the and farked up the hand brake warningbuzzer and the hand brake lite on the dash(dug all the fome out and all was well) still warm air entering up via the handbrake
    Quote Originally Posted by tezza View Post
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    I'd trade you so I could have a 6 seats in my old wagon pity your up QLD.
    VX SS
    Jun 2005
    Quote Originally Posted by justbad4you View Post
    Mine has a hole because the handbrake mounting surround under the car is not there, but I cant say Ive noticed that there is hot air coming from the handbrake area. You might need to cut the carpet slightly, although when you cut it, dont cut the carpet off, but cut a flap so the carpet can sit there which may help.
    If your worried about hot air etc, when you remove the right hand side handbrake lever, it will leave a hole and some gaps. You can put a plastic plug and cover up the hole or make a metal bracket to cover the gaps.
    I havent done it and it doesnt really bother me at all.
  1. 3 seater to 2 seater!! Any ideas?
    By Brownie1986 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-02-2011, 01:13 AM
  2. How to convert a 3 seater vs ute into a 2 seater
    By crozzo_90 in forum General Discussion
    Last Post: 28-10-2008, 03:08 PM
  3. ute 3 seater help????
    By myute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-10-2006, 08:17 AM
  4. 5 to 4 seater
    By fatty in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-06-2004, 08:28 PM
