Results 1 to 12 of 12
Thread: transmission
    VS V6 BT1
    Jan 2011
    south austrailia
    Exclamation transmission
    hi ive got a problem with my trans (6HDD)it will not change into 3rd or forth!i can take off in (D) without any problems or noises changes smooth but gets to 3rd and its like nuetral nothink there everythink else is ok but i cant keep doing 100kms in 2nd as ill blow it up can anyone help me please
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    hello and welcome to j/c
    Quote Originally Posted by VS V6BT1 View Post
    check the colour of the trans oil.
    If it is black then it may be a internal trans problem
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    This link: 4l60e Problems and Solutions - S-10 Forum says: 6. No 3rd or 4th gear: “3-4” clutches are worn out. R&R. The car is safe to drive (in 2) until you can get it fixed.
    Doesn't sound too good. Welcome to the forum.
    VS 5.0 Caprice S2
    Dec 2008
    Armadale WA
    Just recently had the exact same problem and it turned out to be the clutch, like hako said, check your fluid.. If it looks or smells "burnt" then it's most likely the clutch.... Geeze there seems to be a lot of people having trans problems at the moment lol
    VS V6 BT1
    Jan 2011
    south austrailia
    Kerbstomp what did u get done to fix this problem and thanks for your help guys looks like 2011 is gona be just like 2010 crap then
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    VS 5.0 Caprice S2
    Dec 2008
    Armadale WA
    Still in the process of getting it sorted... Rebuild for the box was quoted at $1950 but don't really have this sort of cash spare so I'm looking around for a 2nd hand transmission (around $500 from what I can gather) and will have a crack at fitting it myself.. Every year seems to start off with car problems for me too haha
    VS V6 BT1
    Jan 2011
    south austrailia
    hi guys my car is booked in tomorrow with my boss friend i should be able to tell you whats wrong with it in the next 2 days oh and my my boss is gona pay for it aswell awsome ,his friend said it could be some solinoid ($200) sorry for the spelling! but needs to take the pan of to look at something 1st or the auto has shit its self!! got a quote about ($700) supply an fit so not to bad ay
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    yeah the 3/4 shift solenoid could go or have somehting jammed in valve i suppose
    but unlikely without shift solenoid code and the filter is before the solenoid in oil flow so something inside box disintegrated and stuck in there
    D3V14NT's Avatar
    D3V14NT is offline Likes Shiny Things
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    If you're willing to give it a go, rebuild kits from the US are pretty cheap for these trans. Not really a hard job if you have a decent set of tools and take your time.
    I've got a rebuild kit turning up for a T700 in the next day or too and was quite surprised at how easy they are to work on. If you're doing it yourself you can even spend the money you save on putting in a shift kit or some other goodies.
    1. 1990 VN Exec V6
    2. 1993 VP BT1 3.8L - Now wrecking for parts!
    3. 1991 VP Berlina V8 - RIP
    Looking for a good condition VN - VS V8!!!
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by D3V14NT View Post
    One of the Yank sites has a step by step pictorial on the web on how to strip and overhaul the 4L60E...it is very comprehensive...I've got the link which I'll post when I find it.
    VS V6 BT1
    Jan 2011
    south austrailia
    hi guys my auto is blown that bad it nt even good enuf to rebuild ay owell get my car back wednesday
  1. radiator differences 2 transmission lines or 4 transmission lines...
    By Darkk_Calais in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-01-2010, 12:10 PM
  2. Replies: 0
    Last Post: 17-11-2008, 01:51 PM
  3. Code 68 - Transmission Component Slipping - Auto Transmission Only
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 05:14 PM
  4. vr transmission
    By dantheman78 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-09-2006, 09:12 PM
  5. VK transmission help?
    By *VK*chick in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-08-2006, 06:18 PM
