Results 1 to 7 of 7
Thread: Brake Lines
    Blown V8 94 VR Manual Ute
    Dec 2006
    West Side
    Default Brake Lines
    Hey all, on my car im thinkin of doing my own brake lines with braided lines,
    So from the booster all the way to the caliper but im not too sure if it would work? can anyone tell me?
    Would the hose flex too much and loose performance?
    94 Red VR 5 Litre 5 Speed Super Charged and intercooled = Alot of fun!
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Errm, Why? im not brake expert but the metal brake line is better then the braided line im pretty sure so why dont you want to just replace the oem rubber hose with a braided one? Or are we going for the WOW factor, or just to look cool or something? But yeh you could do it but it would cost a fortune.
    Dec 2006
    West Side
    im just curious thats all.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Well its possible but pointless as the idea of braided lines is to limit the swelling or expansion you get with a conventional rubber hose which then gives a more firm pedal feel. There is no need to run braided lines from master to caliper, although it could look pretty cool, because the metal lines do not swell and the brake fluid gets pushed directly through them without some of its pressure being lost through expansion.
    ephect's Avatar
    ephect is online now Donating Member
    VS Acclaim V6
    Jul 2006
    stick with ur metal lines to each hub, then if you want, braided from there to the calipers. u can chrome up ur lines, or get new ones n have them chromed the replace them in one hit.
    u will have to get it engineered if u want to go braided from master to calipers. not worth it in cost imho
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    thats for sure.leave the metal brake line and do the rest of the hoses(not metal piping) do the hoses in brade(braided lines have flex and im not sue if it would work in replacment of solid steel lines?......i
    Quote Originally Posted by VK SL 3800 View Post
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    vs commodore
    Oct 2009
    Tamworth NSW
    Braided brake lines fitted to registered vehicles,used to be illegal in NSW years ago..I knew a few blokes who got done for fitting them and they had to go back to using rubber lines.The laws must have changed at some time though.I dont get why they would have ruled them to be illegal for use on the road though anyway.They give better brake pedal feel as they expand less under pressure..You can also get fake braided lines.These are rubber lines with a braided sleeve over the top of the rubber line.I dont know if they were ever illegal or not.
  1. hot brake lines
    By Bryza in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-03-2010, 09:25 PM
  2. [VIC] WTB: VS NON ABS Brake lines
    By Thomas1 in forum Swap / Wanted to Buy / Trade
    Last Post: 25-01-2009, 09:12 PM
  3. How to bleed brake lines
    By policehoon in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-11-2008, 11:23 AM
  4. VN brake lines
    By IvegotaCommy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-09-2008, 09:02 PM
  5. Brake lines
    By Bax in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-09-2006, 12:44 PM
