hey guys, so i have a 96 vs calais with a t5 in it. over time the clutch has had a day where it has sliped a little then grabbed. ive put a new clutch cable on and noticed that the clutch fork is all the way back up agaisnt the gearbox so its like its not fully releasing the clutch. i dunno wats goin on. wuldnt be the fork has popped off the pivot or nothing to do with the input shaft. then today its goe like s;lipping more. its got a hd clutch atm. if i got to replace it then standard clutch probably gonna go in. its got a stage two cam.. cheers
I'm not sure exactly what is causing your clutch slip (apart from not releasing), but I'd get it seen to soon, as once they overheat they will distort the clutch disc and/or the pressure plate. One thing you could check is where the cable goes thru the firewall/bulkhead...check for cracks which will affect the cable's operation.
as said check your firewall for cracks
also the clutch fork could have weakened and bent , ive seen that happen before
maybe your rear main oil seal is leaking. if your unlucky enough oil can end up on your clutch plate and flywheel. seen that one or two times.
is your clutch operation smooth? is there any noises or anything when you engage and disengage the clutch?
hey wel the clutch like grabs rite at the end of the pedal travel so its like the thrust bearing has popd of. So i rekon gbox out n il do the clutch get flywheel done n rear main n see wats goin on
also its got crazy clutch shudder. So get everything done so then i can sel it
Its getting oil on it.
$25 bet.
do u think i shuld put another clutch on? I put a hd clutch 20000kms ago. Just get the flywhel machind?
Get the problem diagnosed and fix it properly mate, Why just throw money at it? If its the rear main seal blowing oil on the clutch (possibility) Then get that fixed, then get a new clutch+possibly get the flywheel machined, If its oil on the clutch thats the problem, just chucking a new clutch on is gonna give you the same problem
We'll get a haltech ECU and some high flow injectors too, keep talking, oh keep talking, OTR induction and a K&N filter to boot. - Grease Lightning meets JustCommodores.
Did you do the clutch yourself? when you upgrade to a HD clutch the pivot ball height of the fork has to be adjusted to allow proper disengagment of the clutch.
Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
Did you get dirt/grease on the clutch when your were installing it?
nah didnt adjust it wen i put it in.at the start it was sweet, nah it was al clean wen put in
