Im thinking of puttin FE2 springs and shocks in my caprice, just to lower it a little bit, and because my caprice is irs, will it need a camber?
camber kit? if you want perfect tyre wear it will yes
but going fe1 to fe2 is only a small difference and if you had the front camber adjusted
then had your tyres rotated and balanced regularly you will get little tyre wear unless thrashing it
in which case youd wear them out on fe1's anyway~!
fe1 is stk on the plate in engine bay
i think they still call it that in there parts catalougues?
im not sure of exact measurements
i think it only an inch or more
but have never measured it they are lower visually but i nevver mentioned it
they dont tuck tyres under gaurds like ssl springs mind you but do look better
FE2 is just the option number for sports suspension.Theres a lot of different option codes etc,just like GU4 is a 3.08 ratio rear axle.
Just found this posted up,it shows a few different option codes for VT.:You can see FE2 and GU4 are there in the list.We can see the car was optioned with sports suspension and a 3.08 diff.I dont know what the other options would be.Someone would have a list of what they all are..Anyway thats why its called FE2.Theres no FE1 that Ive seen.Its just called STD I think.
VT factory codes
G'day all,
Just bought a V8 VT cheap and went to install some ICE - Came across a piece of paper under the rear carpet and it has the following options... Can anyone please tell me what they all mean? Many thanks
AH6
AJ4
AQ9
A8Z
C60
FE2
GU4
LB9
M34
N40
PG1
QAH
VA1
yeah stk = stock
which last time i entered the parts at a holden for some shockies they told me that is fe1 or standard suspension like omega is base model it has stk onplate and fe1 suspension? get it?
wowowo you want to know all the codes bloddy hell!~
made a phone call to a car yard mate that has a good memory
he thinks i owe him a beer now!~
and he didnt know anything hardly but air con!~
AH6=
AJ4=
AQ9=
A8Z=
C60=has air con (c61 electronic climate control)
FE2=sports suspension
GU4=
LB9=
M34=
N40=
PG1=
QAH=
VA1 =
he wasnt sure about other ones
What??? I didnt say I wanted to know what they are.You can find them on the net anyway if you look around.Its just an example of the option codes for the commodore.The VS models had the FE2 option available,but the standard suspension option code was just listed as STD in the option code lists for the VS.Ive never seen it listed as FE1, and the compliance plate (on the VS models anyway)also says STD not STK.
std suspension is listed as fe1 in the parts catalouges..... it is standard suspension chill out huh?
private messages and all that not required on this one![]()
The holden dealers and holden spare parts have both told me before when I was enquiring about changing suspension from standard to FE2 on my vs, that theres no such thing as FE1,Its just STD suspension or FE2 sports suspension mentioned in their books or on their computers for the VS.They reckon theres no mention of FE1 and they had never heard of it before.Its even got STD on the plate on the car,theres no STK ,i dont know where that came from.Typical bloody useless holden mechanics,they all say something different to eachother depending on who you ask or which dealer you go to.Ive even had conflicting answers before between the holden mechanics,the holden workshop manager and the holden spare parts guys.They all said something different to eachother.
i pmed you with proof of fe1 in a service information listing will you stop now?
and after all its just a termanology like a rose by any other name still smells as sweet!~
Anyone can write that and post it and send it,so I wouldnt class it as proof..Im only saying what the holden dealers told me around here..As Ive said,Ive had lots of problems where one holden worker says one thing,then another will say something contradicting the other guy.I wouldnt know who to believe.
lol settle down you two, no need to get nasty at each other
anyways,
ive also been thinking about getting king spring SL's all round
what would the height difference between fe2's and the SL's be?
not sure of exact measurements it would be another inch or two id imagine
sl generally require just a little bit more adjustment to wheel alignment than fe2's so it has to be lower then fe2
ffs its just a name bro id give you the link to that proof to see it but you dont have a password..ffs
