Results 1 to 6 of 6
Thread: CV Joint Removal
    96 VS SII 5.0 Calais
    Apr 2009
    Melburn
    Default CV Joint Removal
    Hi,
    The inner cv joint boots have split on my calais. Removed all 8mm hex bolts on both ends, according to the manual and what ive read elsewhere they should just come off after this...but it wont come down seems to catch on its flanges.
    Any ideas?
    Apr 2009
    Melburn
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Never done this myself but from reading what is involved and how they are constructed but I'd say (presuming the car is on stands and wheels still on) you need to raise or lower the wheel (not the body) to move/change the angle the CV flanges join...like reduce the side thrust which is preventing them separating. This may give them enough room to miss the flange.
    Sorry I cannot help more. Good Luck.
    ephect's Avatar
    ephect is online now Donating Member
    VS Acclaim V6
    Jul 2006
    sorry about this, i miss read i thought you meant that your removing the cv from the alxe (which you will need to do).
    to get the alxes off, jus move the wheel up and down as hako said, this will give you enough movement to remove it, you can also tilt the ends of the cv's to give you enough room. the ends of the alxes have a hump which helps to keep the hub within the flange, great when putting them back in the car.
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    personally the reaer cvs on irs i just jack up body so suspension is at full travel
    then hold the inner one and pull it towards the outside of car (wheel)
    it just sort of comes out only has a few mm clearance but it does come out
    Apr 2009
    Melburn
    thanks guys that helps alot, will give them another hassle.
LinkBacks (?)
  1. 17-07-2011, 01:33 PM
  1. VS Esteem CV joint - Yes or No
    By iab48 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-07-2010, 09:48 PM
  2. CV Joint
    By caldonia in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-11-2007, 02:50 PM
  3. Ball joint removal
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-04-2007, 07:52 PM
  4. CV joint problems
    By GeorgeB in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-07-2005, 06:05 PM
  5. Uni Joint
    By midnight.outlaw in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-07-2004, 04:19 PM
