Hey guys,
Gotta take the harmonic balancer off my 1993 VR and was just wondering best way about going to do this ?
My old mans a tire fitter and they have all there rattle guns at the shop I could borrow.. Would these have enough power to crack the bolt loose?
Rattle guns are the best thing to use and the safe way to get that bolt lose.
Thats the best way but there are other ways which will work but not as safe, good luck
Just get a long breaker bar and socket,put it on the balancer bolt and lean the handle of the bar on the chassis rail or the ground so it cant turn,and then crank the engine over.This will loosen the bolt.Then you need a 3 bolt type harmonic balancer puller tool to remove the balalncer,dont use the 3 leg type pullers if the balancer is to be used again,these type of pullers with the legs can seperate the balancers metal and rubber parts,stuffing the balancer.At $200 or more for a new balancer,they arent cheap to replace.The bolts that screw into the balancer have a 1/4 UNF thread.
Rattle gun might be the way to go then.. Sweet! Yeah harmonic balancer is been replaced anyway, I'm gonna duck down tomorrow morning to buy a harmonic balancer puller, will any type fit? From somewhere like supercheap,autopro etc?
normally i just use a three legger but i use the flange on the inside edge (where it slips over crank in middle of balancer)
as long as puller is good it gets them off without damage
hmm hard to explain where to put it... like if you picture the outside where the belt goes then look at the center of balancer and
see where the "spokes" join onto i go just behind the lip of the spokesin the middle of each spoke
and i agree if you have a siezed bolt in the crank (you'd be surprised when a 100ft rattle gun wont get it off first)
a bar can be used but be careful you have the right direction and its not resting onn anything breakable
if this wont get it cranks but wont turn bolt loose
put a jump battery on it with the earth on the metal of the engine (black lead from jumper onto engine hook for e.g.)
the extra electrical energy available can sometimes force it loose
Are they reverse thread or just Normal thread as in lefty loosey, righty tighty? Will see what sort of pullers are for sale here and see how I go..
yes they are the old right is too tight rule (normal bolt)
I just got a cheapie balancer puller from supercheap,and it works excellent.The bolts that came with it didnt fit these balancers though,I also had to go get some 1/4 UNF bolts from the local hardware store for a couple of dollars.The 3 bolts you need should be 2-3 inches long too.
yeah thats right make sure you have correct thread or youls stuff the balancer
as in you wont be able to get it off without specialist expensive balancer puller
i use the super cheap ones but you have to be careful you got them straight ive noted on one of theirs that it bent
only happend once now i make sure the bolt im pushing off has a flat head on it~!
from my experience take it 2 the mechanics i used a rattle gun hdad to take the radiator and shit out to get it in there then it couldnt loosen the bolt so put the breaker bar on the ground and kicked the car it loosend it i had the harminic ballancer puller from supercheap cost me 70 dollars and it broke the puller had crow bars and everything trying to get it off in the end gave up took it to mechanis next day they cost a 120 to do it
Id say you were probably doing something wrong.Ive never had a problem yet.Ive probably done 10 or so of them now.Ive even removed old balancers from engines that were sitting out in the weather and rain for 2 years,and they came straight off no worries.And whatever you do,dont try to lever it off with crowbars etc,this will crush the engines number 2 main bearing thrust faces, thats the part of the number 2 main bearing which controls the crankshaft end float.The bearings are made of very soft metals and it doesnt take much pressure to crush them.
only did it that way because i had the shits it was jammed in there the mechanic was taking quite a while to get it off aswell
