hey just woundering if any one knew anything about the key not working properly in a vs causeing the ignition to stay constantly on, while the key in the barrel still working fine except when the key is turn it turns real easy and feels like its doin nothing
cheers
If the key is stuck on a certain point (eg, acc) and makes no difference which way you turn the key and the car won't crank / start then the most likely thing is that the ignition barrel has snapped - mine did this not too long ago was a pain in the arse at the time.
To start the car you can remove ignition switch from the ignition barrel (2 screws) and crank it manually with a screw driver - however you will still need your key in to disable the immobiliser.
A new ignition barrel costs about $80 coded to your key, you can install yourself with not too much trouble - or call a locksmith![]()
nathans VY Calais - 'Calais 2.0' | VT Equipe | VS Calais **SOLD!**
sweeet as cheers sounds like the problem i have, where do u suggest i get a new barrel from ?
did u take ur barrel off ?
how do u get it of the steering column
ive posted a thread for you to take a look at How to remove a stuck ignition barrel VN-VS
We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
