Results 1 to 4 of 4
Thread: vs auto transmission fit s1 to s2
    1995 Stateman
    Jan 2011
    Sydney Australia
    Default vs auto transmission fit s1 to s2
    Does anyone know if a series 2 transmission will fit a series 1 without the need to change the computer etc..?
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    yes it will [QUOTE=statesman_man;1750806]Does anyone know if a series 2 transmission will fit a series 1 without the need to change the computer etc..?[/QUOTE s1 and s2 flexplates (what theyre called in auto's flywheels for manual) are different but its not really an issue as auto is driven off the torque convertor which bolts to your flywheel.
    both boxes are same hydraulic so no wiring differences or
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    Sep 2005
    yes it will fit
    Quote Originally Posted by statesman_man View Post
    vs commodore
    Oct 2009
    Tamworth NSW
    As long as the transmissions both have 13 pins in their electrical connectors, they will fit the VS.The VR models had the same 4L60E auto transmission,and it will bolt straight up to a VS,but the electrical connector on the VR only has 12 pins,not 13 like the VS,so it wont run properly. This is where it gets confusing.But as I said,just make sure they both have 13 pins in their connectors and they will be fine in the VS.
  1. VE SV6 200 H0 Motor Auto 2008 Transmission Change of Auto oil
    By markholland in forum VE Holden Commodore (2006 - ?)
    Last Post: 31-01-2011, 05:24 PM
  2. Vs auto transmission
    By descentia in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-02-2010, 12:14 AM
  3. Replies: 0
    Last Post: 17-11-2008, 01:51 PM
  4. WTB - VN auto transmission [vic]
    By timmy_tam in forum Swap / Wanted to Buy / Trade
    Last Post: 26-03-2008, 08:08 PM
  5. Code 68 - Transmission Component Slipping - Auto Transmission Only
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 05:14 PM
