Results 1 to 9 of 9
Thread: Torque converter or flexplate? Any ideas will help....
    vr wagon
    Aug 2010
    vic
    Question Torque converter or flexplate? Any ideas will help....
    hi there, i recently had my engine swaped over, got it home and theres a rattle... the guy who swapped it swore blind its a piston while you guys said flexplate... i have un done the brace plate from trans to engine and made sure the bolts on the torque converter were tight. theres a bolt from trans to engine missing and one was loose, i put the y pipe back on and started it up... the rattle in it is definitly the flex plate or torque converter.. the flex plate has a slight wobble and has bits of teeth missing on the edge... any ideas on what the rattle is? cheers..
    vr wagon
    Aug 2010
    vic
    2DIE's Avatar
    2DIE is offline ONEDOLLAHOLLA
    97 Acclaim
    Feb 2008
    South Aus
    Either a cracked flex plate or lose bolt is the most common cause. You will need to drop out the auto to check it properly.
    Best RPG ever
    vr wagon
    Aug 2010
    vic
    had a torch under there and doesnt seem to be any cracks, it wobbles bad at low idle and the sound is worse, could anything in the torque converter be broken?
    vs commodore
    Oct 2009
    Tamworth NSW
    vr wagon
    Aug 2010
    vic
    i have another flex plate off my old motor, might fish around for a torque converter then, is it worth getting a second hand one?
    VR V8 Manual Wagon
    Jul 2010
    When the flex plate cracks, it will crack between the bolts on the mating face where it sits against the crank. It is a commonly misdiagnosed problem. It does produce the same sort of noise under load as a flogged piston. But as said by previous members, the trans needs to be removed.
    VP Exec
    Jun 2005
    If it's wobbling then something is bent or broken. If you are going to swap the flex plate buy new bolts as they are torque to yield.
    vr wagon
    Aug 2010
    vic
    no probs, doesnt make sound under load but noticed the other day it stumbles a bit at 100km/h only makes sound at low revs... going to replace the converter aswell... do you think it could be bearins in the crank?
  1. Flexplate bolts (torque)
    By REWIRED in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-01-2010, 06:12 PM
  2. VR V6 Torque Converter
    By Sara Pax in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2008, 01:20 PM
  3. torque converter
    By kniever in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-03-2008, 03:26 PM
  4. torque converter?
    By xcop5l in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-11-2006, 07:59 PM
  5. torque converter
    By Matt_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-04-2006, 10:51 PM
