Hey im new here just wanting to try find out why my car is being not normal
ok in the last month my car has been playing up. i can start and stop the car a number of times at home b4 the battery gets flat but when you take it for a drive like to a petrol station you fill up then go to start it and it seems like the battery is flat so then you have to get someone to jump start you witch is annoying.
but it did the same thing at home today so i just left it and went in side for a while to find my multimeter i came back out and tested the battery and it was at 100% so i tried to start is and it worked it seems to only do it when the motor warms up
what would it be ? would it have something to do with the starter motor ? i wanna re wire it all what wire should i use and wire can i get a roll of it?
I have no knowledge on this type of stuff but could it be a blown fuse somewhere?
What volts did you get from the battery, both before and after starting it?
before starting it was in the 12.* mark and started some were in the 13.* mark ?
Check the fault codes, but could be crank angle sensor. Does it turn over when it wont start it?
No it just keeps making a clicking sound is the C.A.S hard to change ?
If it's not turning, it's not the CAS. Sounds like a starter motor issue...Have you checked the connections on the starter to see if they're loose?
alt sound its on its way out,if the alt is going it wont recharge the batt fully> it may get you home but when you restart its flat and you get the tick tick....the alt can go on the road and the cars dead.s o get it checked and take it from there
We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
If it's the alternator it shouldnt read 13+ volts while running. But if your gonna replace it, you don't need more amps, you just need one that works.
Ahh ok, I dunno if they fit.
Had a similar problem on VR 6 cylinder Caprice. Good battery but just a tick, tick as if it were dead. Seemed like loose battery connection. Try again and eventually it will start. My son had the alternator replaced. It made no difference. New battery.. no difference. This went on for a number of months. Eventually, I got caught in a carpark. It wouldn't start no matter how long I waited before cranking again. I got the NRMA out and he correctly diagnosed a BAD EARTH STRAP. He said it was fairly common. Oh, and the car started by the time the NRMA came. The earth strap went front the inner guard to under the motor, near the oil filer from memory.
Grab an earth strap from the wrecker instead or get both it and the alternator if you want but make sure you can return the alternator.
Hope this does the trick for you.
"So many roads ... so little time."
I had a very similar problem on my VS so I thought I'd check the battery terminals, when I went to remove the negative terminal the earth cable just fell off the terminal. It was only connected by one strand of wire. New terminal and all fixed!
Try cleaning your battery terminals first before spending any money. I had a similar problem with my troopy and it was dirty terminals.
First of all, batteries can read from 11.80 to 12.xx whilst off. If your car was running you should be showing very high 13s or low 14s. So sounds like your alternator is working.
So your car winds over okay when battery is warm? Sounds like your battery is stuffed.
Do you know someone you can borrow their battery to test?
As mentioned above, clean the battery terminals also.
Good luck with it.
Click Click Click sound is the start motor isn't receiving enough power to wind over and the clicking sound is the solenoid engaging as that doesn't take much power to do. Unless you have burnout out windings in your starter but you mentioned when someone jump starts or when your car is warm the start motor winds over so not that.
Yours Kindly,
Jim
ok so i went to the wreckers today and got all the negative & positive wires off a VY i have put them in my VS so now i have to negative wires from the battery to the frame and to negative wires to the motor and i have to positive wires from the alternator to the battery and to positive wires from the battery to the starter motor i changed the battery from a 320cca to a 520cca so when i get some time 2morrow or in the next couple of day i will try and take it for a drive and see what happen's
Could also be a worn starter motor, my VP used to start like a champ when cold but as soon as the engine warmed up, if you switched off the motor and tried to re-start it, it would crank over very slowly. It turns out that it was slowly seizing up and the heat from the engine was creating higher and higher resistances, which in turm caused the starter to work harder and harder untill it just gave up on me.
Same issue with my VS. No ticking, just reeaaally slow to crankover when hot. Starts up fine when cold. Battery is new. Any ideas?
ok 1st of all 320cca way to small lol you will kill it with a radio,2nd just cause you have full volts reading doesn't mean you have enough amps crankin back from the alternator.Get the alternator out and take it to a decent auto elecky and get them to bench test it.They will easily find out if she gives of enough amps,and if you got her running turn on the headlights and se if she runs a bit funny that is also indication of low amps.It seems you have a connection from your alternator cause your voltage goes up when running so rule that out but still sounds like alternator on the way out,and getting a bigger battery has maybe just slowed the slow death in a supermarket car park cause you just gave it more to feed off if the alternator isn't fully chargeing battery back up after startup.Oh and lazzy starter moter usually gives you a hot earth at the terminal when you touch it,not warm I mean hot.Also check lights like boot light is not staying on stuff like that cause sometimes things like that happen and you get caught out that way too.
i havent had the chance to drive it yet but after adding another set of wires everywere and giving the battery a good charge i left the car sitting turned on in the drive way for about 30 minutes to heat up and then i turned every thing on thats uses power for about 5 minutes you could tell the alternator didnt like it lol but then i turned it off and then tries starting and it worked so far its working just need to drive it and see if it still does it but i might look at getting a brand new alternator what would i be looking at and how much?
