Results 1 to 10 of 10
Thread: oil change for 6speed
    94 vr HSV gts 6speed 5.7stroker 215kw
    Jun 2009
    no where
    Question oil change for 6speed
    hi yah all. I am going to change my gearbox oil it say to use dextron 111 automatic fluid which sound right it is written on the side of my gearbox,i fill it up till it comes out of the filler hole,'that i know'then it says to put an extra 500ml in through the shifter,how do i take the shifter out without droping the gearbox out of the car,do i simply take the shifter of from inside the car? or is there another way of putting that extra 500mls into the box. if anybody could help that would great. gear box is t56 manual.
    VX SS T56
    Feb 2006
    Just take the reverse sensor plug out and fill it through that
    VX SS - Twin 2.5 cat back - MAFLESS Tune - MCAI
    Jun 2009
    no where
    thanks for the answer.would you know if i should replace the seal or would it be ok,not to sure if it has got one or not,
    VT SS 5.7L Commodore.
    Feb 2004
    NSW, Australia
    vs commodore
    Oct 2009
    Tamworth NSW
    Theres a couple of manual boxes around that use auto trans fluid instead of oil.The T5 manual box in the VS for instance.
    Feb 2004
    NSW, Australia
    There you go, I never knew that. I thought Auto trans would be too thin, and it's a hydraulic oil not gear train oil. Learn something new every day.
    Yours Kindly,
    Jim
    Jun 2009
    no where
    can somebody tell me were the reverse senser is? is it were reverse lockout is,is that were i top up the gearbox with 500mls
    vs commodore
    Oct 2009
    Tamworth NSW
    If you gotta add extra oil to the box, and its already overflowing out the filler hole,then just jack up the car on one side so its on an angle, this should allow you to fit in the extra oil in without it running out of the filler hole again.Just dont get under the car unless its properly supported first..This seems a lot easier than stuffing around trying to get oil in through the reverse lockout or whatever.
    VR_Acclaim is offline Banned
    Vr acclaim
    Jun 2010
    Jun 2009
    no where
    thats a great idea thanks for that, saves muck assen around with the sensers
  1. Vz ss 6speed
    By Holdenboy_VS in forum VY - VZ - WK - WL - V2
    Last Post: 09-09-2010, 07:45 AM
  2. SS 6speed clunky box
    By nickel in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 27-04-2010, 04:38 PM
  3. VZ 6Speed in a VT???
    By charlie4401 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-03-2010, 11:22 AM
  4. [SA] VT II SS 6Speed
    By sus_calais in forum Vehicles For Sale
    Last Post: 16-03-2010, 08:21 PM
  5. Dimensions of LS1 + 6speed
    By gen3eh in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-02-2008, 11:06 PM
