Hey, Can anyone tell me how to check the injection pulse, thanx
k from where to wear
so I guess you cant check with a multi meter, Do you need a special meter ??,
As The1 said,you need a proper automotive scantool, (Tech 1 etc), that plugs into the diagnostic connector.(ALDL connector).See holden or an auto electrician, they will have the proper scantool to do this.
I see, Well arent I an idiot, Thanx heaps
you can check it with a noid light
Yeah as mentioned, the injector pulse is far too quick to measure on a multimetre. Other than a scantool, you can also use a 'noid lite'. Think of this as a light globe you plug into an injector harness clip while the motor is running and you'll get a flash of the light each time it pulses.
Z' Series HSV 297KW 6lt LS2 Conversion For Sale!PM Me For Details
you can get a noid light
you just unplug your injector and put the noid light in the injector plug, you will see it flash if there is injector pulse
they are only cheap
a normal test light or multimeter wont read the pulse fast enough
heres a link to a couple on ebay
FUEL INJECTION NOID LIGHT GM PFI SUITS BOSCH 2 PORT (eBay item 250724214226 end time 07-Feb-11 21:41:20 AEDST) : Cars, Bikes, Boats
ELECTRONIC FUEL INJECTION TEST LIGHT SET--NOID LIGHTS (eBay item 300512622284 end time 18-Jan-11 06:58:32 AEDST) : Cars, Bikes, Boats
You can't use a multimeter on hertz can you?
wouldn't that give you pulses per second
I love my car like a child...and because it costs as much too!!...Just like the real thing![]()
MY RIDE: '01 VX S Sedan with absolutely nothing done to it besides having the back muffler removed...and i got a 3 litre turbo diesel Rodeo...Single Cab, with all the bull-bars, spotlights, toolboxes and tradesmans gear on it that i need...
Ah,forgot all about a noid light.Thats probably the cheapest and easiest way.
thanx thats good stuff,you guys deserve a medal.
