Results 1 to 3 of 3
Thread: VS SS antenna installation
    VS SS 185i
    Jan 2011
    wollongong
    Default VS SS antenna installation
    The original radio antenna on the 1995 model is playing up, the replacement says - "Remove hexagon nut" I cant see or feel a nut anywhere! The black plastic surround on the body panel i cant dislodge, and I dont want to break it. I know it isnt major but everything counts. Look forward to your help, Tref.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Welcome to the forum....I think what they are talking about is the hex nut that hold the aerial to the guard - remove the black plastic cover from under the mudguard (the one that keeps mud from caking up), locate the aerial wire where it leaves the body and goes to the mudguard and you will find a big nut that hold the aerial against the mudguard. Loosen that and all will be revealed.
    VS SS 185i
    Jan 2011
    wollongong
    Thanks hako; will be able to have a go at fixing it up!
  1. Electric Antenna installation on standard/non Electric ant VN/VP
    By AlpineRaven in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-09-2011, 03:38 PM
  2. Connecting antenna wire to radio antenna
    By Denno in forum Electrical Wiring / Questions
    Last Post: 02-04-2010, 05:23 PM
  3. vy antenna
    By Ratten in forum Car Audio
    Last Post: 05-12-2008, 09:30 PM
  4. antenna
    By burns#44 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-01-2007, 05:10 PM
  5. VP Antenna installation
    By rusty_29 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-07-2005, 10:49 PM
