Results 1 to 6 of 6
Thread: Memcal question
    VS S Pack
    Sep 2009
    Default Memcal question
    can a late series memcal be fitted to an ealier series car?
    I have a S1 VS V6 with a so called performance memcal and want to put it back to a standard one to see if it makes any difference, I have been given a CXAJ1848 which is from a S3 VS V6 will this work in the S1 ECU?
    Thanks
    Chris
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    yep no problems, there all the same it will work in either vs v6 ecu's, what memcal are you upgrading from? Shift points and pressure is slightly better in later tunes, timing isn't as good as early tunes.
    VS S Pack
    Sep 2009
    Thanks for that - not sure apparently it is a performance one looks like it has been reprogrammed just swapped the memcal and the one I took out has a white sticker saying VSV6 A98 so it is not a factory memcal by the looks
    Chris
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    factory memcal should have a silver looking sticker under the blue cover and say DELCO and a code.
    VS S Pack
    Sep 2009
    exactly why I have no idea what the one in the car was - have changed it over to the S3 factory one just need to take it for a drive to see how it goes
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    the stock memcal that came with the ecu will also be labeled on the ecu itself bottom right four letters.
  1. vr clubsport memcal question
    By reaper01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-04-2010, 07:47 PM
  2. memcal question...anyone.
    By Youngblood in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-01-2009, 04:42 AM
  3. memcal question!
    By VGV85L in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-11-2008, 09:35 PM
  4. Memcal Question
    By holden007 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2007, 01:44 PM
  5. Another Memcal Question...
    By dezrik in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-07-2006, 08:26 PM
