Results 1 to 6 of 6
Thread: urgent Q
    vr
    Aug 2007
    Default urgent Q
    I gotta go to melb to pick up my kid at 6 , But im only runing on 5 cylinders, would this cause any damage, Ive changed plugs, leads,coil, injectors, and still not firing on No 4 cylinder, In a bit of a bind
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Have you done a compression test, could be valve seals or rings? That's about all that's left from what you've changed.
    vr
    Aug 2007
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    How many kays have you got to travel?
    You could get a couple hundred very light footed. Wont hurt it.
    vr
    Aug 2007
    VR_Acclaim is offline Banned
    Vr acclaim
    Jun 2010
    Should be fine it may be ur injectors, pull ur number 4 plug out and see if it's sparking
  1. *URGENT* VS V8 coughin fartin splutterin, occasionally stallin *URGENT*
    By holden_1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-08-2010, 05:08 PM
  2. Urgent help
    By VTSPACK in forum VE Holden Commodore (2006 - ?)
    Last Post: 08-05-2010, 12:18 PM
  3. Urgent!!:(
    By redvnllll in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-01-2010, 10:45 PM
  4. URGENT URGENT alternator wiring
    By Keesh in forum Electrical Wiring / Questions
    Last Post: 19-09-2008, 01:10 AM
  5. Urgent Help Please
    By Cam-shaft in forum General
    Last Post: 13-11-2006, 07:25 AM
