Results 1 to 4 of 4
Thread: tie rod ends
    vr commodore v6
    Dec 2009
    Question tie rod ends
    hi guys just a short one ,i have a vr commodore with a stuffed tie rod end an a family member said some cars have the exact same tie rod end since i cant get anywhere now i thinkin my shitt tr magna has a new one on it an i researced eveything looks the same, but before i do something stupid i just need to know if they are the same they look dead ringer but usally there will be a design differnce or a floor witch stuffs me up can ane1 help
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Measure the taper on the balljoint and the thread pitch and diameter of the tie road. Then compare.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Why take the risk of a catastrophic steering failure for the small cost of a tie rod end?
    Buy a new one that fits.
    ve sv6
    Aug 2010
    vr-vs and vt series 1 use the same tie rod end, magnas are compleatley different. the part# you need is te750 and should cost you no more than $20.00 at worst case. as rx25se said dont risk it, get your local parts shop to order it in or i can supply you one if needed.
LinkBacks (?)
  1. 21-06-2011, 10:15 AM
  1. VZ Tie Rod Ends
    By holdenvtman1123 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-03-2010, 12:20 PM
  2. [VIC] Vt s2 / vx tie rod ends - new!
    By boomnvn in forum Parts And Other Items For Sale
    Last Post: 27-10-2009, 02:33 PM
  3. VN-VS tie rod ends the same?
    By maldotcom2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-08-2009, 10:06 PM
  4. tie rod ends
    By DANNY8 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-02-2007, 09:28 AM
  5. it just never ends
    By impakt in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-03-2006, 10:23 PM
Tags for this Thread
