Results 1 to 4 of 4
Thread: Car stops fuel relay gets hot
    VR Aclaim
    Jan 2011
    Default Car stops fuel relay gets hot
    I drive the car for 10 minutes then it stops the fuel relay is hot and car wont start for about an hour.
    Any ideas what htis could be?
    vs commodore
    Oct 2009
    Tamworth NSW
    It could be that the CAS (Crank Angle Sensor) is stuffed.Its a very common problem and can cause similar problems to yours.Also check for any set error codes,this test is simple to do,and only takes a minute or two.Heres a link to a page that shows you how to do this.Sometimes the CAS will not show an error code,even if it is playing up.Ive seen this happen on more than one occasion,so its something to keep in mind.Its easier to replace the CAS if its more than a few years old.Try to only use genuine holden sensors.
    ---Checking error codes VR/VS (Revised)---
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd go with Bretts advice first, then if no go there, try swapping the relay as it might be arcing inside and then overheating which may kill the power supply to the fuel pump.
    muttley383's Avatar
    muttley383 is offline Donating Member
    VR 383
    Sep 2007
    If the fuel pump relay is getting hot then there is a bad contact heating up or excessive current being drawn. This will in essence reduce the voltage to the fuel pump and inturn not supply enough fuel or stop working all together.
    If it was mine, I would replace the relay or find out why it is overheating.
    muttley383
  1. Replies: 1
    Last Post: 22-11-2010, 08:23 PM
  2. VS stops dead on half a tank of fuel! Please help!
    By lifes_telephone in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-04-2010, 02:35 PM
  3. fuel pump relay
    By brettois in forum Electrical Wiring / Questions
    Last Post: 23-06-2006, 12:00 PM
  4. vl fuel pump relay
    Last Post: 20-06-2006, 11:40 PM
  5. VX Fuel Pump Relay
    By mitch01 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-05-2005, 01:50 PM
