Results 1 to 5 of 5
Thread: vrvs sedan water found in boot how i tested to find where the water was leaking from
    peter1 is offline peter1
    vr series 2
    May 2010
    Default vrvs sedan water found in boot how i tested to find where the water was leaking from
    i found water in the boot so i tested for boot lid leaking there was none, put water around rear window and ran the side of the car, and i found water in the boot again. then i tried again and used food colouring around window gently and not letting it over flow so it went around the seal and the colour used didn't show in boot. So i used a different colour around the metal bit the at covers the metal between the quarter window bottom and the roof between rear windows. Then i opened the boot and found the water with food colouring so i removed the little metal cover and silicone it back on and now it doesn't leak.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Good post - maybe you should do the other side at the same time as they usually leak in pairs. Be careful of what food colouring agent you use as some will stain light colour duco. But that is a good method.
    VR Executive
    Jun 2010
    Rockhampton
    mine was leaking at the rear 1/4 window(crappy foam seal on them),used a bead of windscreen sealant on them,and then had to replace the boot seal,2 weeks solid of rain here in Rocky,there was an inch of water in the boot.may check those cover when i get the chance...
    The Daily:6/93 VR Executive SedanVQ V8 Long Range Tank L3 Dash Conversion VR Calais Leather Seats VR II Steering Wheel VTSS Mags Aqaumarine in Colour
    The Weekender:6/07 BF XR8 6 Spd Manual Sedan Ego Paint Pedders Coilovers Adj.Swaybars Shelby GT500 Rotating Assembly 2800lb Twin Plate Yella Terra CAI FPV Gauge Pod Full Sports Leather Interior
    Tuned by Glenmore Motors,Rockhampton
    -345RwHp,13.8ET with crappy tires and bulk wheel tramp
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    To fix it properly the quarter window has to come out.
    Visit my Facebook page
    vr series 2
    May 2010
    thanks all replies really appreciated. As i didn't know not the food colouring could affect the duco colour
  1. Boot Leaking Water
    By Bladebox360 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-11-2010, 10:28 AM
  2. Water leaking into boot lid
    By Scooter79 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-11-2009, 08:15 PM
  3. Water Leaking Into VX Boot Garnish...plz help!
    By B-T-GiZzLe in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2007, 11:04 PM
  4. Boot leaking water.
    By KLatham in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-01-2007, 09:26 AM
  5. VP Leaking Water Leakage In Boot
    By Sambo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-06-2004, 01:01 AM
