Results 1 to 7 of 7
Thread: window rubber glue ?
    VS commadore V6
    Mar 2007
    Default window rubber glue ?
    My inside window rubber has fallen down inside the door, just wondering if anyone knows what is the best glue to buy to stick it back on, i did try some crap i had hanging around here but it was piss weak.
    thanks
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    G'Day Rony, Just my opinion, but the damn things fall off pretty soon after you stick them back on...plus it's a pain glueing them and trying to attach back correctly....also the rubber shrinks and goes hard thru age. I've left mine in the bottom of the door. Our cars are old enough now and have enough rattles/squeaks so what's a bit more noise.
    Good Luck.
    VS commadore V6
    Mar 2007
    Good day hako, yeah I agree they are getting a bit old these days, i will try to stick it back on though, if it comes off again stuff it then, I had the same trouble with one of my older cars, the guy who put it back on told me not to use the window for a couple of days to give the glue a chance to really set, it worked but don't know the type of glue he used.
    thanks mate.
    Coast_Calais is offline sick of the idiots here
    varies
    Jul 2008
    gone
    contact cement, or sikaflex...
    but let it cure for as long as you can before you start using it again...
    VS commadore V6
    Mar 2007
    WL Statesman....L67 VS Berlina
    Jan 2009
    Newcastle
    yeh mine did the same thing i used contact cement MAKE sure you clean BOTH contact surfaces
    and it DOES work put it on leave it about 3 mins and push both tegether and good..
    mines been holding for 6 Months Plus....
    VP Exec
    Jun 2005
    I've found that 5 minute epoxy works well. Using some masking tape looped so the sticky side faces away from the flocking helps hold the rubbers in place while the adhesive sets.
  1. repaintion window surround rubber part?
    By jas98 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2009, 01:07 AM
  2. vs window seal rubber
    By Johnno.o in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-03-2007, 07:30 AM
  3. Rear Window Rubber Seal Vt.
    By fabz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2007, 07:31 PM
  4. respraying VP rubber window trim.
    By pow3rslave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-12-2006, 01:24 AM
  5. Front Window Rubber Seal
    By VTSSDUDE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-08-2005, 02:42 PM
