Results 1 to 5 of 5
Thread: Vs Low/High Idle and Cutting out + Error Codes
    VS SS
    Jan 2009
    WA
    Angry Vs Low/High Idle and Cutting out + Error Codes
    Hi
    So i took my car for a drive all was fine , Left it for a day or two jumped in it and started and cut out straight away every time unless i had my foot on the pedal to hold up the revs, Then the next time i tried it the rev's were to high 1200-1300 so i checked the error codes and this is what i got
    Code 16 - Coolant temperature Sensor voltage unstable
    Code 35 - Idle Speed error
    Code 36 - Vacuum Leak
    Any help would be great
    Did have VS Berlina now have VT Berlina
    Mar 2010
    Cockatoo Vic
    VS SS
    Jan 2009
    WA
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    ask brettJJJ HES pretty good on this stuff
    Quote Originally Posted by Unfolded-V8 View Post
    Any ideas?
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    check your vacuum hoses, check the cable to the CTS, then reset the computer and try again.
  1. HIGH beams cutting out
    By drift-it in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-03-2010, 05:30 PM
  2. VY trouble codes/error codes. NEED HELP!!
    By GILLO in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-03-2009, 04:04 PM
  3. VT SS 5.0L cutting out at high rpm
    By hsv8 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-07-2008, 03:00 PM
  4. Error Codes
    By DND in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-09-2007, 07:57 AM
  5. engine cutting out when cruising+under high load
    By gambit120 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-09-2005, 05:03 PM
