Results 1 to 6 of 6
Thread: radiator for 5 ltr engine
    vr statesman 5.0 + vs exec s2 auto
    Mar 2006
    central coast, nsw
    Default radiator for 5 ltr engine
    i just need to know from forum members what radiator is best for replacement , alloy or copper ? my vr 5 ltr has copper radiator , but is leaking . maybe some of you can advise which is the best against corrosion , and what lasts longer. hope you can help , thanks.
    VS 5 Litre BT1
    Jul 2006
    I had to replace my radiator a couple of years ago. From the research I did, it appeared that going with an alloy radiator with the cast iron block could cause corrosion problems with the alloy radiator in the short to medium term so i went with the standard spec as a replacement.
    VR SS
    Sep 2010
    I got a replacement radiator awhile ago and my mechanic suggested and fitted a new original Holden one for my 5ltr
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    I had alloy in mine, it corroded, busted a pipe and caused then engine to overheat, replaced it with a HEAVY DUTY steel? one.
    VS SS
    Aug 2010
    ACT
    I got a original from Holden, didn't really pay attention to what its temps were before but hasn't over heated ever, even with sitting in 45mins of standstill traffic in 30 degree heat at the end of the coast trip didn't climb over were it was sitting.
    Mar 2006
    central coast, nsw
    thanks guys for your help and opinions . i am getting an all alloy radiator with alloy tanks , its got a 52 mm thick core for 249 dollars that includes courier from QLD hope i dont get one that eats it self up lol . any way i flush the cooling system and change the coolant every year so fingers crossed.
LinkBacks (?)
  1. Flushing Radiator + engine maint
    By Paulib in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-12-2010, 08:13 AM
  2. Temperature Light and Gauge Hitting H but engine or radiator not hot...
    By Harry Krishna in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-12-2010, 09:02 PM
  3. VT engine/radiator heat help
    By Gokz777 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-07-2010, 11:15 PM
  4. engine oil in radiator
    By nuked in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-04-2010, 12:20 PM
  5. Engine Oil In Radiator
    By pedrod59 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-07-2009, 11:02 AM
