Results 1 to 3 of 3
Thread: vt brake upgade .abs calipers* ar all vt calipers abs ready
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    Default vt brake upgade .abs calipers* ar all vt calipers abs ready
    im about to start sourcing vt brake upgrade parts? what id like to know is>>> i have abs on my ute,when i get the vt calipers will all vt calipers be able to be fitted to my vs ute(i have abs) or do some vt calipers not suit abs? also will i need a bracket for the calipers as part of the package? and were if i need 1 will i be able to get 1 >? its a series 111 ute will the rotors fit straight on? ,,,,,,for any info i thank you in advance...best wishes and kind regards. ps also if im going to a holden wreckers to source the parts would there be a later model holden comm upgarde im better off looking at and getting than the vt upgrade?...have a good weeek end
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The ABS is part of the front hub and you won't be changing the hub so no problems. Read this how-to.....it will answer ALL of your questions: How To - VT Brake Upgrade
    Sep 2005
    thanks mate
  1. [VIC] VT front calipers + discs/ vn-s rear calipers painted in 2pak red
    By wildss in forum Parts And Other Items For Sale
    Last Post: 21-05-2010, 09:30 PM
  2. CR8 brake calipers
    By topdzl in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-04-2010, 06:24 AM
  3. [NSW] SWAP: My VZ Calipers for near new VS Calipers-fronts-Sydney
    By 2Com in forum Parts And Other Items For Sale
    Last Post: 09-05-2009, 01:27 PM
  4. VS brake calipers on a VN
    By Philth in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-03-2009, 08:54 PM
  5. brake calipers
    By vr-man in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2008, 08:58 PM
