Page 1 of 2 12 LastLast
Results 1 to 25 of 36
Thread: replaces snapped belt and now wont start
    VS ute
    Jan 2010
    townsville
    Default replaces snapped belt and now wont start
    My belt snapped today. i replaced it with a new one and now my VS V6 ute wont start. it cranks fine.
    two points:
    plug to oil pressure switch came off
    i had to pick bits of shredded belt from behind harmoic balancer.
    im thinking its the crank angle sensor.
    any ideas?
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    crank angle sensor or wiring busted
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    What he said, look at the harmonic balancer, you'll see all sorts of grief.
    You're going to cry when you get the bill too...
    VS ute
    Jan 2010
    townsville
    as it happened last night in the dark i couldnt see shit, so im about to go have a look now. it shouldnt cost too much as il do everything at home.
    with the oil pressure switch. should it still be able to start even if the wires were broken? or it was disconnected?
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    VS ute
    Jan 2010
    townsville
    there are 3 wires to the il pressure switch. which wires do i have to bridge to bypass the oil pressure switch?
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Does it have spark?
    Can hear the pump buzzing in the tank (get someone to crank it)?
    VS ute
    Jan 2010
    townsville
    im not at the car at the moment. im waiting for someone to pick me up and take me there. im not sure if there is no spark or not.
    man plan basically is...
    if the fuel pump isnt turning on im goin to bridge the wires on the oil pressure switch.. if it is working and there is no spark then im puttin the car on a trailer and taking it home and throwing a new crank angle sensor on it.
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    Sounds like a plan.
    I change CAS every 100,000kms regardless to eliminate headaches.
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Quote Originally Posted by The1 View Post
    no the oil switch runs through the fuel pump, so no pumping fuel if no oil pressure.
    Thats not right.
    Fuel pump builds pressure before you even start the engine - its the whirring sound you hear when you turn the key to the 'run' position
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    it'l prime but if the oil pressure switch doesn't short the wires after starting the fuel pump relay wont click to keep it going. If im reading the wiring diagram correctly Or it just runs as a backup circuit
    VS ute
    Jan 2010
    townsville
    Quote Originally Posted by Andrew426 View Post
    Thats not right.
    this is very true.. there fore it should start if the oil press switch was not operating or there was a broken wire to it..
    im just going to trailer it home and go buy a new oil pressure switch, crank angle sensore, waterpump(waterpump isnt spinning perfectly straight, id imagine thats why the belt came off in the first place) and some filters, oils etc for a service. might as well make a day of it
    hakhawk's Avatar
    hakhawk is online now smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    Thats not right.
    fuel pump will always prime, but the oil pressure switch is hooked to the fuel pump relay, if the motor loses pressure, it kills the pump, so motor konks out and you have less chance of paper weight'ing your motor.
    vs commodore
    Oct 2009
    Tamworth NSW
    The fuel pump is wired through the engine oil pressure sensor/switch so if the ECU fails,and cant command the fuel pump on, or goes into limp home mode as its called,the oil pressure switch will turn on the fuel pump once the oil pressure gets up to around its running pressure.
  15. #15
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    LOL If the oil pressure switch wiring was broken, wouldn't this also result in no oil pressure?
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
  16. #16
    hakhawk's Avatar
    Jan 2005
    Quote Originally Posted by Mumboman View Post
    oil pump creates oil pressure, the switch just reads the pressure and opens or closes an electronic circuit depending on what pressure its reading.
  17. #17
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by hakhawk View Post
    Exactly right.The pump creates the oil pressure,the switch just reads the pressure.A broken pressure switch wont cause a loss of oil pressure.
  18. #18
    в∞ѕтεכ √&
    Jul 2008
    NZ
    yes and the switch is only a backup as above you can unplug the oil pressure switch and the car will run .if the wires happen to be earthed out due to broken sender unplug it it may run again but my bets on smashed CAS or bent fins on the balancer that chop through the cas to make spark happen
  19. #19
    VS ute
    Jan 2010
    townsville
    ive done a diagnosis test and it came up with Code 46 - No Reference Signal While Cranking
  20. #20
    Nov 2008
    Smithton, Tasmania.
    CAS and reluctor wheel are shagged, $50 bet. Look just behind the harmonic balancer.
  21. #21
    VS ute
    Jan 2010
    townsville
    yeah i presumed that from the start. i just thought id post up the codes for future reference when someone else experiences the same problem
  22. #22
    Nov 2008
    Smithton, Tasmania.
  23. #23
    VS ute
    Jan 2010
    townsville
    one more question. whats the thing called that works with the cas with the fins? is that hard to replace? might get one of them while im at it
  24. #24
    Nov 2008
    Smithton, Tasmania.
    That's the relluctor(?) wheel.
    If you go to a wreckers and get an ecotec harmonic balance they usually come with them.
  25. #25
    VS ute
    Jan 2010
    townsville
    can u get them seperate from the harmonic balancer?
  1. re vr wont start snapped timing chain
    By bear76 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-05-2010, 08:28 PM
  2. Timing belt replaced,,now car wont start!!!
    By boohsv in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-11-2009, 01:52 PM
  3. fanbelt snapped replaced it now car wont start what could be the problem
    By vn_sleeper in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-09-2009, 02:15 PM
  4. vx ss fan belt snapped
    By Sir VxSs in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-08-2009, 11:18 AM
  5. Timing Belt snapped at 38km have I stuffed it?
    By NAILS in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-06-2009, 07:00 AM
