hi there i have a vr commodore and the airbag light stays on after i start up the engine and have taken it to a local mechanic and said that ther are no error codes and have tryed changing ecu and the dash but is stil stays on any ideas ...... any advise welcome
or does anyone no of any1 who can has and use a tech1 scan tool in perth to help me wif my problem for cheap im on a shoe string buget thanks
ecu has nothing to do with the airbags at all and checking ecu error codes wont show airbag codes need tech 1 scanner like holden has
The SRS module is located under the front drivers seat,its a black metal box.Its probably faulty,or its wiring or connectors..If you replace it with a second hand SRS module,make sure the car the SRS module comes from, has got the same SRS setup as yours,eg-single drivers side airbag,or both drivers and passenger airbags.If its different from your setup,the SRS light will come on and error codes will set.A brand new SRS module can be configured for single or duel SRS airbags with the Tech 1 scantool.The Tech 1 can also connect to and read SRS error codes.These are different error codes to the ECU error codes, and can not be read without a Tech 1 scantool.
I have a list of the SRS error codes.Remember,you need a Tech 1 scantool to be able to read and clear these SRS codes.
13 Driver's Airbag Circuit Short to Earth
15 Driver's Airbag Circuit Short to Battery
23 Passenger's Airbag Circuit Short to Earth
25 Passenger's Airbag Circuit Short to Battery
31 Driver's Airbag Loop Resistance High
32 Driver's Airbag Loop Resistance Low
33 Passenger's Airbag Loop Resistance High
34 Passenger's Airbag Loop Resistance Low
43 SRS Warning Lamp Short to Battery
44 SRS Warning Lamp Circuit Fault
48 Ignition Input Voltage Low
49 Ignition Input Voltage High
53 Configuration Mis-Match
55 Sensing Diagnostic Module Fault
66 Airbag Deployment Commanded
Unplug each wheel sensor and using a mulitmeter set to A/C volts, spin each wheel and see if you get a small voltage generated.
This will eliminate the common fault of a dodgy wheel sensor.
Then find a another mechanic.
thanks guys ill try ur ideas out thanks
normal culprets are the clock spring in the stearing wheel and the seatbelt pretensioners or turning the ignition on with the gauge panel out of the dash
