Results 1 to 9 of 9
Thread: Motor hard to turn over
    VY II SS
    Jun 2005
    Default Motor hard to turn over
    Hey guys I have a problem with my car, I cracked the timing cover and replaced this now the motor seems to struggle to turn over even by hand. It does turn but not easily, starter turns it over maybe twice before giving up? Is it possible to have done harmonic balancer up to tight so its hitting timing case? I havnt touched anything else since last drive
    Any help would be great
    Michael
    VY II SS
    Jun 2005
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    nar can't do the ballancer up to tight, sounds like somethings not right, unfortunatly you might have to go back and check everthing, was everything in order before you put the cover back on? How'd the old timing cover crack or where?
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Remove balancer and turn it over.
    If its still tight, pull the next bit off.
    And so on, and see if it frees up.
    VY II SS
    Jun 2005
    Ok have pulled balancer off cranked did same thing, pulled spark plugs out reduce compression motor turns over fine plugs in = very hard to turn over
    vs commodore
    Oct 2009
    Tamworth NSW
    It might just be a weak or half flat battery.Turn the headlights on to high beam, and try to start it,do the headlights go dim or go out completely,try it and see what it does and let us know..You could try using jumper leads and another battery connected up with yours.Take note of how good it winds over then.
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    I agree with brett. Sounds like the battery.
    Check its done up right and that the strap to the starter is good.
    VY II SS
    Jun 2005
    When I jump it it starts I have come to the conclusion my alternator isnt to good as soon as I take jumper leads off car dies almost right away
    Nov 2008
    Smithton, Tasmania.
    very probably.
LinkBacks (?)
  1. How hard is it to put a vt motor in a vr
    By murpha1818 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-09-2010, 11:23 AM
  2. hard to turn the key
    By az_sv6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 17-02-2010, 07:22 PM
  3. How hard to change for s1 to s2 motor
    By 91vn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-11-2009, 08:29 AM
  4. Have fuel and spark but motor still wont turn over
    By ascension24 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-01-2008, 03:13 PM
  5. power steering to hard to turn
    By bigjas in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-10-2006, 06:23 AM
