Results 1 to 15 of 15
Thread: Playing up VS.
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Default Playing up VS.
    Ok well, the starting of this car is getting worse.
    Even when warm it takes a bit more than a car should.
    Was only when it's cold.
    Have replaced the fuel pump, plugs and leads are 24,000k's old, battery is over a year old, fuel filter was changed 24,000k's ago.
    Could it be a starter?
    Or CAS?
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    vx s pack II
    Jan 2010
    aLKIDA
    Check for codes first off.
    Check for spark,also check whether the spark is weak or strong. If there is no spark then look into the ignition side of things. CAS, coils, Dfi module,
    Also wiggle the Dfi module plug while starting the car these are common problems on the commodore.
    Check fuel pressure.
    A bicycle
    Aug 2009
    Gippsland, Victoria
    done a load test on the battery mate?
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Quote Originally Posted by NonStick Squid View Post
    @old mate you drive a vs ute therefore you're a bogan therefore your point is invalid
    vx s pack II
    Jan 2010
    aLKIDA
    Does it crank over but does not fire or does it struggle to crank?
    If it does not fire then do as i mentioned above.
    If it struggles to crank then check the battery connections clean if necessary check the earthing to the chassis also inspect the thick power cable from battery to starter motor.
    Check for voltage drop with a multi-merter should be under 0.05volts.
    If theres is a voltage drop run a new cable from battery to starter.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    What do you mean by "takes a bit more than a car should"?
    When you turn the key to 'crank' does it take a while before the starter begins to work?
    Once the starter turns over the motor, all is OK?
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    Guessing he means it turns over but takes a while to fire up.
    Pravx is heading in the right direction.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    Quote Originally Posted by PRAVX II S View Post
    Yea, it cranks but takes a while to fire.
    Done error codes a few weeks ago.
    Had this problem for ages!
    When cold and you hit the accelarator the car will lose revs then go up (only in first couple mins). Other than that car runs fine after starting.
    Quote Originally Posted by old mate View Post
    Nope... Prob should look into that one...
    Quote Originally Posted by RX25SE View Post
    Nah, just takes a while to fire.
    My Commy
    Discuss.
    vx s pack II
    Jan 2010
    aLKIDA
    Its nothing got to do with the battery because its cranking over. It is said that when cranking over a car the most current is consumed.
    So load testing wont fix your problem.
    You have to go through a process of elimination. Check for spark first were this is the easiest,Check for fuel pressure in the fuel rail.
    than go from there. It could even be dirty or blocked injectors.
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    It's just started to get worse.
    A while ago it would do the usual when cold but warm would start straight away.
    How am I checking fuel pressure?
    With spark, just remove lead and check lead for spark?
    I remember when a mate was checking for a dead coil pack he got a good shock out of one of them...
    My Commy
    Discuss.
    vx s pack II
    Jan 2010
    aLKIDA
    You should buy a book on your car M8. Its pretty hard explaining everything online.
    You will need to buy some tools first to check fuel pressure and a spark plug tester to test for weak spark.
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    I have a book but didn't think to check it. XD
    Well I did get the pump replaced a few months ago so that should eliminate the pressure?
    My Commy
    Discuss.
    vx s pack II
    Jan 2010
    aLKIDA
    Quote Originally Posted by Wombles View Post
    No mate there is also a thing called fuel pressure Regulator.
    Have a read. look properly in the book. It takes time to fix properly.
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    Ok, well I have to buy some parts then...
    I'll see how I go.
    Does it matter what temp the weather is with what could be the cause?
    Seems to take longer to turn over in the cold...
    With testing the plugs for good spark, can I just test the leads for a resistance or is it completely different matter.
    My Commy
    Discuss.
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    Ok well, I got a spark tester. Couldn't get really close to the plug /lead end so I got the edge of it where the wire goes into the bulky bit. It tested as weak... So might be a DFI module or something? They all tested the same...
    My Commy
    Discuss.
  15. #15
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    Hmm. Did work on the injectors. There fine. Put new filters and caps on them.
    Bad part is that it's still the same.
    My Commy
    Discuss.
LinkBacks (?)
  1. 19-11-2011, 04:31 PM
  1. Help VR BCM 885 LUX? + I think the bcm is playing up
    By hsv91ss in forum Electrical Wiring / Questions
    Last Post: 20-05-2009, 09:01 PM
  2. Help car is playing up
    By Holden Chick in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-09-2008, 05:48 PM
  3. Air con playing up
    By anotherstockvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-03-2006, 05:52 PM
  4. playing Around with my VT
    By limnuy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-11-2005, 08:19 AM
  5. Currently Playing
    By Troy711 in forum The Pub
    Last Post: 13-07-2005, 09:54 PM
