Results 1 to 9 of 9
Thread: Disconnecting Battery
    VS Calais
    Jul 2010
    Australia
    Default Disconnecting Battery
    I'm not going to drive my car for one week so I was wondering is it a good idea to disconnect the battery? It is a brand new battery as well. Would the battery lose any of its charge if I decided to not disconnect it? I've had previous battery issues with an older battery which is the reason I'm considering this.
    Any advice is appreciated
    Cheers.
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    I reckon the battery should be fine and will last a month connected...
    Atleast!
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    Matty.b is offline VR with 56,000kms genuine
    VR Executive
    Jan 2009
    Coal Fields, Queensland
    vs commodore
    Oct 2009
    Tamworth NSW
    It will be right for just a week.If it was for a month or more Id say to remove the battery terminals and connect a battery changer to keep it charged.
    VS Calais
    Jul 2010
    Australia
    yeah, thought so. usually four weeks isn't it? my old battery used to last two days so now ive become cautious. thanks for the advice everyone.
    vx s pack II
    Jan 2010
    aLKIDA
    Quote Originally Posted by commodorev6 View Post
    Cheers.
    You dont need to disconnect the battery it should be fine. If it does go flat there is a drain in your car.
    VS Calais
    Jul 2010
    Australia
    White Tiger's Avatar
    White Tiger is offline Semper Fidelis
    VN Executive Wagon VR Berlina V6
    Jul 2009
    Bordertown SA
    can you unlock the car manually whilst the battery is disconnected?
    as long as you have a key for your door
    VS Calais
    Jul 2010
    Australia
    yeah thats good then. thanks for the advice again.
  1. disconnecting the battery
    By elmaso in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-08-2010, 07:17 PM
  2. VS V6 out of tune after disconnecting battery ?
    By greenacc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2008, 04:54 PM
  3. Disconnecting battery and having to reset ecu?
    By Da_Blak_Ravn in forum Electrical Wiring / Questions
    Last Post: 05-04-2007, 05:42 PM
  4. Disconnecting the battery
    By Fu Manchu in forum Electrical Wiring / Questions
    Last Post: 04-04-2006, 07:29 PM
  5. will disconnecting battery prevent airbag error code being sent
    By muso in forum Electrical Wiring / Questions
    Last Post: 18-09-2005, 07:28 PM
